Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz
Old 24th July 2014, 05:24 AM   #81
ozcal is offline ozcal  Australia
I'll take one 0.02 board please.
Old 24th July 2014, 06:04 AM   #82
Calvin is offline Calvin  Germany
Calvin's Avatar
even upsamplang and automatic detection of clockrates, that´s what I iked to hear from You
Think You´re on the way to building a really well sounding DAC
Keep going.
jauu
Calvin
Old 24th July 2014, 06:18 AM   #83
ekidnah09 is offline ekidnah09  Australia
Default one 0.02% board
Please put me on the list for one 0.02% board.
Thank you
Old 24th July 2014, 06:34 AM   #84
TV Man is offline TV Man
Very nice project!
I'm interested in one or two boards .02
Thanks!
Old 24th July 2014, 07:20 AM   #85
kazap is offline kazap
kazap's Avatar
Great project
My wish list:
Id like a 0.01% version please.
24bit depth is more then enough for not limiting the SNR
can you design a variable max voltage/currant through the R2R to achieve the best SNR zone and/or control the Vout/volume in a novel and loss free manner.
Can the opamp output be changed to allow flexible options by using an opamp socket Then users can plug in their chip of choice eg some will want to use the AD844 feedback free route while others will want to "roll" opamps.
Old 24th July 2014, 08:34 AM   #86
esgigt is offline esgigt  Netherlands
Originally Posted by HpW View Post
Ok, the temperature coefficients on those resistors are very important! Not only telling the 0.0x% precisions!
Nice would be some spline oversampling as WADIA used..
Low level linearity may done as I did using a fast test setup...
See picture
I guess that type of oversampling ought to be implemented in the firm-ware?
Old 24th July 2014, 08:49 AM   #87
HpW is offline HpW
Yes, this requires a DSP...
Hp
Download FFT Analyzer & Generator at www.hpw-works.com
Old 24th July 2014, 11:29 AM   #88
soekris is offline soekris  Denmark
Originally Posted by kazap View Post
Great project
My wish list:
I decided on 28 bit, to have headroom for a perfect digital volume control. At -72 db volume you still have 16 bit resolution with perfect linearity thanks to the sign magnitude architecture.
Can't change voltage/current though the R-2R network, is already optimized.
The LME49724 is only available in SMT, and I also don't like sockets.... Normally I like discrete amplifier designs, but the opamps choosen are the best. And the "raw" R-2R resistor string outputs are available for anybody who have different opinions on buffers....
Søren
Old 24th July 2014, 11:31 AM   #89
kuribo is offline kuribo
interested in 3 boards...
Old 24th July 2014, 11:36 AM   #90
Eldam is offline Eldam  France
Banned
Wow..... I need to improve my soldering skills if such a project gets born with a bare pcb to be populated!
If not too expensive with FGPA already soldered, I'm in !
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KhzHide this!Advertise here!
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 05:11 PM
384 Khz DAC? SunRa Digital Source 8 1st October 2009 11:14 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 01:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 05:14 PM
Copyright ©1999-2019 diyAudio
