Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz Please consider donating to help us continue to serve you.
Old 20th November 2019, 09:04 PM   #8671
soekris is offline soekris  Denmark
Originally Posted by living sounds View Post
Hi Søren,
are you still planning on doing a SAR ADC? I still think there would be a market for it (and I would certainly buy it).
Yes, I have stuff in my CAD system and are moving forward.... Not sure how to sell them if I make one, it will probably not be a DIY project, although I'm considering a special deal for people her....
Søren
Old 20th November 2019, 09:05 PM   #8672
TNT is offline TNT  Sweden
Nice!!!
More distortion to the people!
Old 21st November 2019, 01:19 PM   #8673
living sounds is offline living sounds  Germany
Exciting!
From my perspective this is predominantly a pro audio device and would make most sense as a finished unit with input clipping protection and a state of the art input stage. DC coupled and offset taken care of with a servo (that's how Prism Audio does it).
As for marketing, news would spread quickly through message boards. I know I would create shoot outs and post these online, and other people would as well. And I would tell anyone in the studio world who would listen if this audibly beat the current S-D AD converters in the same way the DAM1021 beats the S-D DACs.
Maybe the tricky part is the filter? TNT's creation earlier this year took the DAM1021 to a whole new level. It would probably be a good idea if it were user programmable. And I guess there will be an analog filter stage in front as well...
Old 8th December 2019, 04:13 AM   #8674
kenneth_obee is offline kenneth_obee  Hong Kong
Hi everyone,
I got a problematic dam1021, it always jump to prompt when I connect the serial without pressing +++. Moreover, the input always set to I3, and the firmware revision is incorrect. I have upgraded the firmware to 1.21 (latest) still no luck.
(The first one is a normal dam1021, which can show the revision correctly. The lower one is the one with problem)
Before upgrading the firmware to 1.21, it was v0.8
Old 8th December 2019, 04:56 AM   #8675
If it shows rev F.F, then the FPGA image is not downloaded correctly. The uManager should always work, even with incorrect FPGA image.
The image get downloaded directly to the FPGA Flash, it's not like it get loaded afterwards.... I'm using the same source code as for my line of embedded computers, so it should be ok.
I'm using HyperTerminal on Windows, that I never had any problems with.
The same issue was mentioned in post #1434.
The rev F.FF means problem in firmware...
I tried to flash the firmware to 0.9, then to 1.06 then to 1.21 but still the firmware is F.FF.
Soren, is there a way to reset this thing? Thanks !
Old 8th December 2019, 11:56 AM   #8676
No need to reset anything, if uManager runs, you can download new firmware.... Are you remembering to use the "update" command after downloading new firmware and then do a power cycle ? The 2nd picture still show rev 0.8....
Søren
Old 8th December 2019, 12:39 PM   #8677
The second pic was the very beginning.
I take off the board and clean up. Now it is back to normal.
Old 3rd January 2020, 11:45 AM   #8678
NickKUK is offline NickKUK
Interesting: US6307490B1 - Digital to analog converter trim apparatus and method
- Google Patents
I see that the 1999 patent for R2R resistor trimming has just expired.
Old 3rd January 2020, 02:15 PM   #8679
analog_sa is online now analog_sa  Europe
analog_sa's Avatar
That must be very exciting but cannot see it as being useful to this particular thread or audio dacs in general. Has this patent been ever implemented anywhere?
Old 3rd January 2020, 02:19 PM   #8680
The Holo Audio May uses R2R trimming and states it is patent pending - given there's prior art that has now expired, I wonder how valid that claim is. It does open the door for other R2R manufacturers to review the patent positions and possibly offer R2R trimming.
The R2R trimming would help the linearity (a weak spot in the soekris and others).
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KhzHide this!Advertise here!
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 06:11 PM
384 Khz DAC? SunRa Digital Source 8 2nd October 2009 12:14 AM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 07:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 02:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 06:14 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
