Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz
Closed Thread
Old 18th January 2019, 08:12 PM   #8141
ynmichael is offline ynmichael
Originally Posted by TNT View Post
Why you would one use anything else than linear is beyond me as the other stray away from the sampling theorem.
Why do people use tube amps
Old 18th January 2019, 08:14 PM   #8142
danny_66 is offline danny_66  Belgium
danny_66's Avatar
Default is linear.
The interesting options are pass band, stop band and SB attenuation.
Here you can go from a brickwall to a gentle slope.
My RefSpeaker
Old 18th January 2019, 08:15 PM   #8143
TNT is offline TNT  Sweden
Whats wrong with tubes?
More distortion to the people!
Old 18th January 2019, 08:23 PM   #8144
Sweet Distortions? Don’t know much about them just meant to be an example
Old 18th January 2019, 08:24 PM   #8145
Originally Posted by danny_66 View Post
Default is linear.
How does the linear compare to EQHQv5 apo, objectively?....
Old 18th January 2019, 08:27 PM   #8146
analog_sa is online now analog_sa  Europe
analog_sa's Avatar
Is upsampling not offering some alternate reality?
Old 18th January 2019, 08:29 PM   #8147
I believe linear is supposed to reproduce signals under Fs almost perfectly with some well understood artifacts that may be way below hearing limits? Or maybe we’re still treading around that limit
Old 18th January 2019, 09:01 PM   #8148
Got the resampler to work, pretty user friendly and the graphs are very useful. Still not sure if it's better than FPGA 2k/4k taps implementation. Caution: the ability to run Amanero at its full 384khz capacity may produce an overwhelming sense of power
My corrupted psychology tells me the sound is much much smoother. Perfection
Old 18th January 2019, 09:09 PM   #8149
Jogi is offline Jogi  Germany
Great, you did it. And yes, much smoother even when I didn't upsample at the beginning. Especially the high freq are far more natural to my ears.
And I am thinking about what music next
The good news for Soeren is that the bottleneck is not so much the hardware. OK, still a little
Old 18th January 2019, 09:27 PM   #8150
Uses 1-2% CPU. The smoothness is probably not imagined... and the highs are still there. I would prefer to see at least an attempt at a theoretical explanation before I settle on it though... This is certainly something nice to try for those of us using USB, not so perfect for the SPDIF folks....
Closed Thread
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KhzHide this!Advertise here!
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 06:11 PM
384 Khz DAC? SunRa Digital Source 8 2nd October 2009 12:14 AM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 07:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 02:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 06:14 PM
Copyright ©1999-2019 diyAudio
