Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz
Closed Thread
Old 18th January 2019, 07:04 PM   #8131
danny_66 is offline danny_66  Belgium
danny_66's Avatar
Originally Posted by ynmichael View Post
Why do you think it works? Does foobar have a longer filter than the onboard one?
The Resampler-V plugin uses the SOX and the SSRC libraries.
Those libraries are much more extensive then what you can put in the FPGA.
Also the Resampler-V plugin uses the much larger processing power and memory of your PC.
My RefSpeaker
Old 18th January 2019, 07:05 PM   #8132
TNT is offline TNT  Sweden
But when you feed 384 all user editable filters are skipped - so nothing to compare to.
More distortion to the people!
Old 18th January 2019, 07:12 PM   #8133
Jogi is offline Jogi  Germany
Yes that's true, but I have no desire whatsoever to compare. It is too obvious, no way back for me.
Old 18th January 2019, 07:13 PM   #8134
ynmichael is offline ynmichael
Originally Posted by Jogi View Post
I have no idea why, but it is so much better, try it. And I'll have a look at Jriver too now...
Danny, take care of your ligaments...just today a friend destroyed some in the knee skiing.
It might just be a different filter. I don’t doubt that you believe it’s better though. Would you care to try 1.19 linear vs partypak bank 2 EQHQv5 apo? The new stock filter has way more bass and maybe a bit “smoother”, can’t say which is better but partypak is theoretically sound. You can update filter by “download” in umanager and power cycle.
Old 18th January 2019, 07:13 PM   #8135
danny_66's Avatar
Yes, the filters are then defined and processed in the Resampler-V plugin.
You can compare the different Resampler-V options:
sox, ssrc, minimal, intermod, linear, pass and stop band, SB attenuation
My RefSpeaker
Old 18th January 2019, 07:16 PM   #8136
Also the Resampler-V plugin uses the much larger processing power of your PC.
Okay. I’ll try it with newNOS in the afternoon. I would love to put my Xeons to good use
Question, what’s the SOTA with SOX libraries, if a comparison can be drawn with the the filters we have in the FPGA
Old 18th January 2019, 07:24 PM   #8137
So what "filter" are u using when producing 384 kbps by the plugin.
Aren't u just up-sampling? Why a filter?
Old 18th January 2019, 07:33 PM   #8138
danny_66's Avatar
Yes, I'm upsampling.
With filter I meant the options I can select: minimal, intermod, linear, pass and stop band, SB attenuation
My RefSpeaker
Old 18th January 2019, 07:42 PM   #8139
I have the Dam1121, so I don't know how the software and filter situation is right now. AFAIK I have Bambadoos filter pak installed.
Old 18th January 2019, 07:55 PM   #8140
Why you would one use anything else than linear is beyond me as the other stray away from the sampling theorem.
Closed Thread
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KhzHide this!Advertise here!
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 06:11 PM
384 Khz DAC? SunRa Digital Source 8 2nd October 2009 12:14 AM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 07:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 02:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 06:14 PM
Copyright ©1999-2019 diyAudio
