Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz
Old Yesterday, 11:10 PM   #8041
ynmichael is offline ynmichael
Originally Posted by TNT View Post
Pic of reconstruction filter caps. and vRef mods.
I'm now on FKP2 since 30 minutes. This is much more easily consumed. And yes some beaming in the upper midrange is gone. Stage larger but a little more fuzzy where the room ends. More bass. Did the cheap styroflex have anything on these... there was something exiting that I can't really put my finger on... lets listen for a few days on these now....
The cheap styroflex are probably for the explorative and curious...
Is FKP2 better than ceramics?...
Seemed like diminishing returns...
You could be wrong Especially considering that a LSB in 16bits is almost the diminishing returns you're looking at...
Do my 0 ohm hurt?
Does my 0.1 ohm hurt SQ?...
Old Today, 12:11 AM   #8042
Originally Posted by bambadoo View Post
To be clear.
Here is my cap mod.
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz - Page 372 - diyAudio
Each cap is 1000uf . 4*1000uf each rail.
But I got a pm from a great guy. One suggestion was reducing the value of the series resistor. I did only have approx 170mohm there. I parallelled it with another 180mohm. => 90mohm.
I also removed C135 and C142 just for the fun of it.
Things became alot better.
Need to order some more resistors. (0.01ohm as I dont have these on hand. ) and 499r as suggested at moreDAMfilters. Do some testing afterwards.
At least it seems as the value of the series resistor make a quite a big role in the SQ of the dam (maybe especially with added capacitance).
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KhzHide this!Advertise here!
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 06:11 PM
384 Khz DAC? SunRa Digital Source 8 2nd October 2009 12:14 AM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 07:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 02:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 06:14 PM
Copyright ©1999-2019 diyAudio
