Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz
Old 8th November 2018, 04:33 PM   #7731
maikel76 is offline maikel76  Thailand
Originally Posted by living sounds View Post
You mean J3, right? Why would it be easier?
In my case I couldn’t get J10 serial to work but I could get isolated serial on J3 to work.
That was just my experience, what Randy said makes sense too.
Old 8th November 2018, 07:23 PM   #7732
Greg Stewart is offline Greg Stewart  United States
I vaguely remember the isolated serial connection is TTL level and requires a 3.3V signal level, but the non-isolated one works with 5V (not sure if it also works at 3.3V).
I haven't connected to mine via serial for 2 years or so, but I do remember I have 2 USB-Serial adapters, one with a TTL (3.3V) level that I use when connecting via the isolated connection and the other with a 5V level for the regular connection.
AND I found, like Randy, that the non-isolated one was a little easier to get a connection on, but both worked when using the appropriate level output.
See HiFiDuino, this post, for some of the info... the rest is as I remember in this main thread many posts ago:
The Soekris R-2R DAC: Technical Details | H i F i D U I N O
Search for 'serial'.
Greg in Mississippi
Everything matters!
Old 9th November 2018, 01:23 AM   #7733
Greg in Mississippi
Aah thanks Greg, that totally makes sense. I connected my ISO serial to a raspberry pi, which indeed uses TTL level.
Old 10th November 2018, 02:35 PM   #7734
henrylarsen is offline henrylarsen  Denmark
Default DSP and two DAM 1021
I have until now used one dam1021 followed by an electronic crossover. I have however been intrigued by trying two dam2021 with a Minidsp Nanosharc. It works flawlessly. I have not had time yet to check out the sound quality, but I have high expectations, also now having the option to easily play with different filter options.
Old 11th November 2018, 11:40 AM   #7735
hop.sing is offline hop.sing  Europe
Originally Posted by soekris View Post
I have some new dam1021 firmware for testing, it hopefully should fix the issue some are seeing with small "clicks" on rev 1.19, I can't be certain as only some have issues and my prototypes here don't....
For now it's just the fpga firmware for testing, just down and install as normal, firmware 1.19 must already be loaded, if not install firmware 1.19 first.
http://soekris.dk/download/dam1021/1021fpga_120.skr
Please let me know how it goes asap.
Hi Soren
i just installed the update on a v3 board and unfortunately it did not solve the issue with the clicks. The clicks are on the toslink connection as well as on the i2s line from the raspberry.
Going back to 1.06 solves the issue.
Best Tobias
Old 11th November 2018, 02:49 PM   #7736
living sounds is online now living sounds  Germany
Hi Soren,
is there any news regarding a possible ADC based on a SAR chip?
Old 11th November 2018, 09:12 PM   #7737
soekris is offline soekris  Denmark
Originally Posted by hop.sing View Post
Hi Soren
Best Tobias
Thanks for the feedback, I'll continue the work on fixing it.
Søren
Old 11th November 2018, 09:15 PM   #7738
Just for info, we have added an US online reseller, I know many of you have been waiting on that, they will carry the whole lines of dams and dacs.... Please visit them at:
https://www.modhouseaudio.com/
Søren
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KhzHide this!Advertise here!
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 06:11 PM
384 Khz DAC? SunRa Digital Source 8 2nd October 2009 12:14 AM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 07:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 02:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 06:14 PM
