Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz
Old 10th October 2018, 03:23 PM   #7701
spikestabber is offline spikestabber  Canada
Originally Posted by Keetesyflush View Post
Ok, so quick update from my troubleshooting. I measured the shift registers and got some really wacky voltages back. Really low, like +/-0.4v on all 4 rows.
Well, I ended up hooking up directly to an 8vac transformer instead of the 12v power supply I was using and it worked! Everything, including the shift registers, measured correctly and I got glorious sound!
So, pretty sure the power supply is the problem. Got a different one arriving in a few weeks and hopefully will be in business.
Thanks so much for the pointers. Measuring the shift registers was what got me on the right track
Did you figure out what was wrong with your power supply? You said a 12VDC supply but you definitely need the negative component of that supply for it to work with a common ground. As in +/-12V.
EDIT: Another common fault is using a pair of 12V supplies to get a bipolar one but for that to work the transformer windings have to be completely isolated from eachother without a centre tap. The centre tap in this case just creates a short circuit. One can also run the boards on +/-7VDC if you are only using the raw output and not the opamp buffered one.
Soekris dam1021-12v2 dual-mono balanced: https://imgur.com/a/fD68M Update: https://imgur.com/gIn6Nkx
Hypex nc400: https://imgur.com/iORCyna | Overkill TT2USB: https://imgur.com/a/p6OiS
Old 13th October 2018, 08:22 PM   #7702
androa76 is offline androa76  Slovenia
Soekris please for explanation.
I already asked but will again.
Why is at SOFT filter at firmware 1.19 frequency response rising till 20khz ? Is it deemphasis in script?
In comparisson i put pictures of 1khz, 10khz and 20khz SOFT sine wave and 10khz vs 20khz MINIMUM filter sine wave where we see normal falling response at that frequency.
Old 16th October 2018, 08:36 PM   #7703
Can anybody tell me if i can upload old 2k filter F5, F6 into 1.19 firmware or i must downgrade firmware to 1.09? Thank you.
Old 16th October 2018, 09:19 PM   #7704
Any expalnation why Soren use on all designs smd decoupling caps also on GND pin?
So near VDD 3,3V on dam1021 uses 4,7uf smd and near gnd pin 0.1uf? Why 100nf so far away on the other side of clock?
Picture is from dam 1121 but similar as dam1021.
Old 16th October 2018, 10:13 PM   #7705
arnd13 is offline arnd13  Germany
Hi Søren,
can you give us an ETA for final 1.20 Firmware and Filters (dam1021).
THX a lot
Old Yesterday, 11:15 AM   #7706
janho12345 is offline janho12345  Germany
Anyone here tried hooking up two dam1021 to one Toslink?!
Doesn't work for me. I just wired them in parallel but nothing.
Old Yesterday, 07:23 PM   #7707
restrav is offline restrav  United States
please reply to my email for support. any one of the six that i have sent over the last month will do. I dont understand why i have not received any communication regarding the DAc that i sent for repair but please consider getting back to me.
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KhzHide this!Advertise here!
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 05:11 PM
384 Khz DAC? SunRa Digital Source 8 1st October 2009 11:14 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 01:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 05:14 PM
