Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz
Old 16th May 2018, 03:19 PM   #7321
maikel76 is offline maikel76  Thailand
Originally Posted by Dimdim View Post
DSD over PCM is true DSD. PCM is just a container for the DSD "payload".
But the DAM also supports "native" DSD.
Both ways of transmitting DSD yield the same result.
But in the end, the DAM will convert DSD to PCM on order to convert it to analog. It has no other choice - it's an R-2R converter.
There are very few dac chips that manage to do DSD without first converting it to PCM, but that has very little to do with how the dac sounds in the end.
Interesting, thanks Dimdim
Old 16th May 2018, 05:15 PM   #7322
sfox7076 is offline sfox7076  United States
Are there any other connections on J10, or just the three listed?
Old 16th May 2018, 06:34 PM   #7323
henrylarsen is offline henrylarsen  Denmark
Not for the sake of interacting with umanager if this is what you ask about - sorry I just saw that you have it working - so you are probably asking about something else?
Old 16th May 2018, 06:36 PM   #7324
No. Just wondered if it had another purpose.
Old 20th May 2018, 02:22 PM   #7325
gapson is offline gapson  Hong Kong
Hi Soren,
I got the DAC1541 and my friend just past me a Singxer F-1 XMOS USB.
I would like to see the difference by connecting the Singxer usb to the DAC1541.
My best guess was the "J3" jumpers on the DAC board. May I obtain the information on it? Thanks.
Old 20th May 2018, 08:48 PM   #7326
soekris is offline soekris  Denmark
Originally Posted by gapson View Post
Hi Soren,
I'm not sure what you're asking for, but if you want to try to connect an external USB to I2S interface then it's not possible nor needed, the dac1541 have its own perfect USB to I2S interface and it cannot be bypassed.
Søren - www.soekris.dk
Old 21st May 2018, 02:07 AM   #7327
manniraj is online now manniraj  India
One question to users who are using Amanero (un-modified version) pairing with the Soekris DAC. What firmware on Amanero do you use to get the DSD playback? As I think I am using the CPLD_for_1080 + Firmware 1.096c3w2 and I get screeching noise when I play a DSD file either via Windows 10 PC + Foobar or Raspberry Pi + moOde OS. I have even tried different images like Volumio, Rune but its the same issue. Is the problem with the OS that I am using or the players (in case of Foobar) or the correct firmware on the Amanero?
Old 21st May 2018, 06:33 AM   #7328
arnd13 is offline arnd13  Germany
With the standard settings of the amanero board you have to enable DoP (DSD over PCM) for playback in the player(s) not "direct" DSD.
Old 21st May 2018, 02:02 PM   #7329
Yes correct I have that setting to "Yes" on the moOde OS.
Old 21st May 2018, 03:36 PM   #7330
Soekris firmware is 1.06 or greater with normal filters?
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KhzHide this!Advertise here!
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 05:11 PM
384 Khz DAC? SunRa Digital Source 8 1st October 2009 11:14 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 01:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 05:14 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
