Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
First One - mosfet amplifier module
Old 20th May 2014, 09:44 PM   #771
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Originally Posted by back View Post
i received four modules yesterday here in crete.
beautiful LC thanks.
they will go inside active speakers so what about grounding?
just heatsink connected to mains earth?
Hi
If the heatsink is the whole amp chassis bolted to back panel of the speaker, then yes, only heatsink connected to mains earth. GND from SMPS output goes to the earth bolt too, meaning all together two wires connected to this earth bolt.
Regards, L.C.
Old 20th May 2014, 09:56 PM   #772
Mark Verhoeven is offline Mark Verhoeven  Netherlands
Anyone compared the FO to any of the Holton modules?
Old 20th May 2014, 10:53 PM   #773
Lazy Cat's Avatar
Originally Posted by taccodude View Post
How high can the temperature go and where to measure.with FO ?Today I hooked up the FO with a simple PSU and not so big Heatsinks. After 2 Hours we reached 62C on the thick Part of the Heatsink where the Finns are,is that still ok?I shut it of then.Sound is good so far,very detailed even in Bass Area ,dead quite,wonder what`s gona happen with SMPS,if it`s really a big jump up.
62 C is too hot too handle, your heatsink is way too small. Idle power dissipation should bring the amp heatsink to 46 C in a long term. Look for the heatsinks which have 0,4 K/W. What do you mean by SMPS big jump up?
Old 21st May 2014, 04:26 AM   #774
Lazy Cat's Avatar
Ooo yeah SQ will jump up hehe
Old 21st May 2014, 08:21 AM   #775
danny_66 is offline danny_66  Belgium
danny_66's Avatar
Ok, good to know.
I still have a Hifi-2000 03/400 case, a 03/300 has 0.41 k/w so a 03/400 is about 0.31 k/w.
That will do nicely with my speakers which dip to 3ohm@100-200Hz
My RefSpeaker v2
Old 21st May 2014, 11:27 AM   #776
Edgar is offline Edgar  Norway
Edgar's Avatar
FO arrived to Norway a few days ago. This is a nicely made diy-product you made for us Lazy cat!
I'm figuring out how to mate your amps to my coldamp sps80 psu. I have attached a picture modified from the coldamp manual. I have added a connection from input gnd on amps to earth on smps. In the manual it states: "Note that output GND is electrically isolated from mains and Earth". Does this seem ok to you?
Old 21st May 2014, 11:51 AM   #777
Lazy Cat's Avatar
Edgar, look very carefuly and compare it to stereo connection sch from First One user manual and you will see they are 100% the same.
As we experimented with GND wiring for best results, my advice is to remove all three green wires and connect only main GND pin from SMPS to earth bolt.
Old 21st May 2014, 11:56 AM   #778
Lazy Cat's Avatar
Originally Posted by danny_66 View Post
Ok, good to know.
Hi Danny
That would be just perfect.
Regards, L.C.
Old 21st May 2014, 02:14 PM   #779
camelator is offline camelator  France
Agree, and please LC correct me if I am wrong, but I think it is better to have a star ground. To do it, it is better to link speaker GND together to PSU GND and PSU GND to amplifier GND.
Am I Right?
Old 21st May 2014, 04:11 PM   #780
Lazy Cat's Avatar
Am I Right?
No, not in this case, speaker GND has to be connected on the First One module, mandatory.
In previous post I have explained correlation between GND and earth potential. Star GND has nothing to do with earthing and is already done on First One PCB.
First One - mosfet amplifier moduleHide this!Advertise here!
800 Watt MOSFET Amplifier Module The Saint Holton Precision Audio 75 18th July 2013 11:16 AM
MOSFET POWER AMPLIFIER MODULE IN EBAY INDIA reji Vendor's Bazaar 0 19th March 2013 01:52 AM
class D amplifier module,power amplifier module sunlight009 Vendor's Bazaar 2 19th October 2011 01:02 AM
NX400 - 400W RMS@4Ohms Lateral Mosfet Power Amplifier Module by Class-D for sale magnum_1 Swap Meet 16 13th June 2009 03:59 PM
Help with Mosfet module please Beejay Solid State 6 11th September 2008 03:21 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
