Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Amplifier Modules and PCBs For Sale
Thread Tools
Old 18th January 2021, 02:12 PM   #1061
bobo le chat is offline bobo le chat  France
bobo le chat's Avatar
No photo, card and power still on a board and not in a box before the next cards.
It is much more comfortable for modifications.
JLester
For the deletions of the ca3.6 and cb3.6 white Led version, am I correct?
ca3ca6cb3cb6.pdf
Roger
Old 18th January 2021, 02:57 PM   #1062
JLesterP is offline JLesterP  Philippines
Originally Posted by stef1777 View Post
Bobo, do you have a picture?
JLester
Attachment 912983
Roger
Deletion of ca3.6 and cb3.6 is for Versions V1, V1A, V1B.
I'm using V1B and got shocking result (but you guys are not lol), so I think you also need to replace RA7 and RA8 to 2.2 ohms since it is default on V1A and V1B.
Lester
Old 18th January 2021, 03:14 PM   #1063
Is it the capacitors with a red dot on my pdf?
Old 18th January 2021, 03:28 PM   #1064
Yes, correct
Old 18th January 2021, 04:49 PM   #1065
commstech is online now commstech  Singapore
Lester
what is the purpose of reducing this resistance value? can i just short it out?
Old 18th January 2021, 05:00 PM   #1066
Using RA7/RA8 helps with stability (although the amp is still stable if we short them). Since we are using PFFB and have removed C_Op feedback caps, shorting out RA7, RA8 might make the amp unstable in some conditions (we have different setups so it's risky to recommend shorting them).
We are reducing the value to get optimum sound without compromising stability.
Add (or delete) resistors in series with opamp's power supply rails
Old Yesterday, 05:39 PM   #1067
My hunch is correct that the sound is being limited by the opamp feedback caps. Might be the group delay between the opamps are different.
In slaa788A, they increased it for stability from 22pF to 330pF (corner freq is ~48kHz in PFFB).
I think as long as the module is stable, the value can be decreased. In my module, the whole amp is stable even when the opamp feedback caps were removed (using LME49860).
Further upgrade is matching the resistors of SE to Diff buffer, as well as PFFB resistors. It will lower down the distortion further.
Hello
Aop input / output with 330pF 10kHz
Best regards
Roger
  Reply to this post
Amplifier Modules and PCBs For SaleHide this!Advertise here!
Thread Tools
Sale - First One Amplifier ( 4 modules ) scoutOne Swap Meet 3 17th January 2015 05:38 AM
Class D B&O Power amplifier modules for sale audiosteve Swap Meet 0 2nd July 2014 04:03 PM
12 RTS100 100 Watt Amplifier PCBs for Sale AAK Swap Meet 11 4th March 2012 12:43 PM
Limited Edition NX400NP Synergy Amplifier Modules For Sale!!! The Saint Vendor's Bazaar 11 7th June 2008 01:34 AM
NX150 Amplifier Modules Version One On Sale The Saint Vendor's Bazaar 10 10th April 2007 03:49 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
