Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
"The Wire" Official Boards for All Projects Available Here!  BAL-BAL, SE-SE, LPUHP
Old 31st March 2019, 12:59 AM   #1061
picovolt is offline picovolt
Smile Thanks Owen!
Hi Owen,
Thanks for the speedy and assuring reply—the board image helps a lot also. (It used to be so easy to look at aboard and see pretty much everything.) I'm going to need to study the board image to understand the V+ caps, this is still a bit of a mystery to me.
And thanks again for the wire series; it has brought me many hours of listening pleasure!
Old 6th April 2019, 01:39 AM   #1062
aive is online now aive  Australia
Owen's back!
Sabrosa requested a photo and further details of the MPUHP amp. I've attached a photo and schematic.
Owen - I hope you don't mind me sharing these. Let me know if its an issue.
Old 6th April 2019, 04:07 PM   #1063
opc is offline opc  Canada
opc's Avatar
Hi Aive,
It has been a while! I don't mind at all
How have they been working for you? I'm finally back to using my pair as the main amplifiers with my line arrays after finally getting a pair of subwoofers to integrate properly.
Owen
Old 6th April 2019, 04:40 PM   #1064
Dmytro19841 is offline Dmytro19841  Ukraine
Hi, Owen!.
Are BAL-BAL SE-SE, PSU boards available?
Is it possible to deliver to Ukraine?
If I sign up, how much time will it take to prepare the boards for shipment?
Old 7th April 2019, 12:05 AM   #1065
Originally Posted by opc View Post
Hi Aive,
Owen
I’ve been using the MPUHP the entire time, still my only speaker amp :P Still sound stellar to me - I still haven’t cased it though ><
I also got an active sub to support my LS50s :P the upgrade itch never ends.
Old 16th June 2019, 01:57 PM   #1066
IanAS is offline IanAS  England
Sorry if this is a question already asked and answered many times over recent pages.
What op-amp is substituted for the LME49990?
AD797?
Can it be done instead with the OPA1632?
Old 17th June 2019, 09:25 AM   #1067
Sorry, I meant can the phono stage be done with 3 x OPA1632 instead of 3 x pairs of 49990 (797)?
Old 17th June 2019, 10:20 AM   #1068
BamboszeK is offline BamboszeK  Poland
OPA1632 is fully diffrential dual opamp. It is special type and can't directly subtitute most of opamps.
LME49990 can probably be replaced by OPA1611, AD797, OPA828 or any other high performance single opamp. This isn't that straightforward and will probably need lots of testing to ensure stability, performance and compensation.
Old 17th June 2019, 11:09 AM   #1069
Thanks for your response
With 'The Wire' phono stage, a new PCB would be needed, but could the 1632 replace the pair of op-amps, and join the two inputs, and feedback after the 1k's, together with the 100 Ohms?
3 Stage Balanced Phono Preamp.pdf - Google Drive
I recall OPC saying that before the 49990 his favourite op-amp was the AD797, as it was mine, in general. But that was many years ago. I'll have a look at the OPA1611 and OPA828.
&quot;The Wire&quot; Official Boards for All Projects Available Here!  BAL-BAL, SE-SE, LPUHPHide this!Advertise here!
WTB---The Wire headphone amp boards (bal) kuribo Swap Meet 0 31st December 2012 11:03 PM
OPC’s The WIRE – Latest Generation - PCBs for sale (4x BAL-SE, 1x SE-SE, 1x PSU KIT) fualcr Swap Meet 0 15th February 2012 11:39 PM
The Wire Bal-SE and PSU board particleman14 Swap Meet 4 14th January 2012 04:10 AM
SE-BAL Conversion for Function Generators luvdunhill Equipment & Tools 1 9th January 2012 03:23 AM
SE-BAL-SE Switching Joshua_G Tubes / Valves 22 15th September 2010 11:58 PM
Copyright ©1999-2019 diyAudio
