I`ve been searching both Mouser and digikey for this capacitor and didn`t find anything close..
What size capacitor it is???
Thanks.
RS Components have them on stock. 1500 uF/200 V: 30 mm diameter x 50 mm height.
Heatsink testing in forthcoming VSSA home (old Rotel amp).
Heat sinks not so big but still manages about 20C above ambient at ~14W (VSSA bias).
Looking forward to this build
Very good home for VSSA. BTW package is already in Sweden as tracking is showing.
I got my boards and they are very well made.
Thanks also for the nice instruction manual.
WOW so fast, in one day by regular national post. Thanks for the info Joachim, hopefully instructions will guide you well. Please send some feedback, closed loop hehe
I go the Frickelfest until next week but then i will build it.
I already have cabinets. You are suggesting a Hypex PSU.
Which one was that and did you do any modifications ?
I know this information is in this thread but i did not find the time to read everything.
Do you recommend double mono ?
Yes, recommendation goes to SMPS400A180 unregulated +/-45 V, 400 W power supply. In short modification encircles all ELCOs in the power path:
- 820 uF to 1500 uF/200 V EE series, 105°C, 5,22 A ripple (Panasonic)
- 100 uF to 220 uF/50 V FR series, 105°C, 1,6 A ripple ( Panasonic)
- 10 uF to 47 uF/50 V FR series, 105°C (Panasonic)
- 12 V Schrack relay to short inrush NTC after 2 s, driven by SMPS's auxilary +23 V
After this mod the output voltage drop and ripple parameters reduced to half. Sound one level higher over classic linear PSU.
Thanks.
Actually, package arrived today. But unfortunately I got home too late in order to pick up package at the post office ... will do tomorrow.
The -3db point is around 1.2~1.3 MHz.What is the -3dB of the working closed loop amp? You can check that point for a sinewave going from 6 graticules down to 4.25 since you got 4MHZ gen capability. Shaan's 1k 100pF input LPF should kick in for about -3dB @ 1.6MHZ anyway.
Tested with resistive load only, test leads (no speaker wire), no zobel installed, +/-37V rails.
Measured using cursors with the scope on digital setting, and checked against the input at that frequency to make sure the input did not change. The o-scope readings are fairly accurate, but the manual frequency adjustment on the signal generator is very sensitive in the 1-4MHz range, so adjusting the frequency to match the 3db drop exactly, is pretty much impossible.
A square wave is recognizable to about 600-700KHz. The Cat knows his business...
I'll post some pics tomorrow when I have a chance to get them off the camera.
Thanks.
I have the same issue in Canada and USA...
You can order them from RS components or Farnell Export.
Ciao!
Do
VSSA PCB sets packaging big time. Much more fun doing it by listening VSSA simultaneously
Hi Andrej, do you send notifications to members by email if their VSSA kit is ship out? On my case, it will be good to know or to have heads up since I'm always traveling.
Small off topic
VSSA is getting more popular due to some advertisment.
Version with irfp in progress
VSSA Lateral MosFet Amplifier - dyskusja - DIY - Audiostereo.pl
- Vendor's Bazaar
- VSSA Lateral MosFet Amplifier
