Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 1st March 2019, 11:58 AM   #141
32y0 is offline 32y0  Netherlands
Is it possible to use the ISS with the DG300B? If so, should parts of the soft-start on the power supply board be omitted?
Old 1st March 2019, 05:06 PM   #142
tomchr is offline tomchr  Canada
tomchr's Avatar
Sure. You can do that. Just short out the CL-90 on the DG300B supply board. You can omit the relay on the DG300B supply board as well.
Take the mains output of the ISS from terminals 1 and 4 on the transformer primary connector. Bring those to the mains input terminals of the DG300B supply board.
It sounds more complicated than it is.
Tom
Modulus-86, 186, 286, 286 Kit, & 686: 40-240W (8Ω) at <-120dB THD. HP-1: 3W/20Ω, -130dB THD, 128dB DNR.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 1st March 2019, 05:11 PM   #143
tomchr's Avatar
I'm down to 11 DG300B board sets, by the way.
If you prefer to avoid the SMD soldering, I have six of the 5.0 V and seven of the 6.3 V versions of the Filament Regulator in stock.
Tom
Old 19th March 2019, 02:22 AM   #144
tomchr's Avatar
Six board sets left in the stack.
Tom
Old 19th March 2019, 09:35 PM   #145
tomchr's Avatar
Four board sets left.
Tom
Old 24th March 2019, 04:15 PM   #146
tomchr's Avatar
Three board sets left.
Tom
Old 24th March 2019, 08:43 PM   #147
tomchr's Avatar
One board set left.
Tom
Old 24th March 2019, 10:12 PM   #148
tomchr's Avatar
The last board set has sold and the DG300B is retired. Thank you to everybody who has supported this project through the years, and especially to those who bought circuit boards.
Thanks,
Tom
6AV5GAs Re-Visited -OR- Pretty Darn Good SE Amp hareynolds Tubelab 28 7th July 2015 05:58 PM
PGP (Pretty Good Poweramp) syn08 Solid State 263 4th April 2013 06:28 PM
Copyright ©1999-2019 diyAudio
