Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Vendor's Bazaar Commercial Vendors large & small hawking their wares |
Thread Tools |
#61 |
A couple 86s would fix it.
#62 | |
садовник
With ac-heating I imagine that the filament structure and anode/grid overlap may influence any assessment of modulation effects - specifically any effects due to time varying cathode-anode voltage (due to the filament voltage alternations). But with dc heat, the fields remain static, so will there be any special considerations in this case? I can't see any reason for it. If the dc is noisy, then that's a different matter of course. But it is not too difficult to achieve ripple levels of <1mV even without any voltage feedback loop at all. If you try your 45s on ac heat, take some spectrum from simple tones and look out for the 50/60 or 100/120Hz sidebands - the amount seems to vary from type to type, so maybe your structure observations can be witnessed here, acting together with the low voltage [2.5V] across the filament in the case of the 45. Even with acceptable levels of hum, though, you still face the other bugbears of ac-heat: - exposure to the emissions at the transformer secondary. Screened windings mandatory, common-mode chokes, and ferrite sleeves are helpful. (but these do not compare with the insertion loss offered by 50pF of NPN transistor, in the case of a good transistor solution); - the transformer secondary (<0.5 ohm for a 2.5A winding) shunts the filament [2 ohm], so you get some circulation of cathode currents around this long loop, subjected to noise along the way, dielectric exposure, etc. Trying out different transformer construction types shows widely different sound, if you want to quantify these effects. on top of the modulation effects! I have not tried the 45 personally, but with the DHTs I have experimented on, the sound of ac-heat is murky and inarticulate compared to properly implemented dc. In fact, the quickest way to tell whether you have made a good filament regulator, is to quickly switch between ac and your creation, and listen. The difference should be unmistakeably positive. |
#63 |
In this vein tubelab has commented significantly on IM distortion generated by 50/60Hz AC heating in the 45. It's quite significant, might want to ask him about it..
Noting that all of this could be regarded as off topic from the original purpose of the thread, perhaps it would be a good idea to discuss this somewhere other than Tom's thread? (Unless he is OK with it.)
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine |
#64 | |
While the discussion of various filament types and how different types of filament supply topologies impact the performance of a DHT amplifier stage is interesting, I really do believe that it would be better served in a separate thread. I would like the SNR or on-topic/off-topic ratio of this thread to be higher than it currently is. Thanks, ~Tom |
#65 |
Agreed... was not my intent to start another thread discussion here, only to point out that much is being discussed about effects of the cathode wire, types of DC heating and deeper aspects, but nobody was considering the actual physical construction of the DHT in use and I think it matters. So back to our normal scheduled programming....
Regards, KM
... just because you're paranoid, it doesn't mean they're not after you... |
#66 | |
Anyway. Today's musings involve the LM20333. That's a nice little regulator. Compared with the LM3102 it offers higher output current (3 A vs 2.5 A) which would allow some margin when used with a 2A3 for example. It also has a tad better line and load regulation. The main drawback seems to be that it's a traditional current/voltage feedback controller, hence, stability vs a wide range of output currents may be a bit tough to achieve. I'll have to do the math and see... ~Tom Last edited by tomchr; 6th June 2011 at 07:36 PM. |
#67 |
Mucked some more with the circuit. Reducing the switching frequency from 800-ish kHz to 600-ish kHz (R2 = 68 kOhm rather than the 47 kOhm I was using) made the IC run some 15~20 degrees (C) cooler. It did not affect the ripple voltage, only its frequency.
I also made another observation (which is probably old hat to most switchmode designers). There is considerable voltage drop across the ground plane. In some places I can measure upward of 20 mV of drop. Needless to say, in the final implementation, the top and bottom plane will have to be stitched together in several places to ensure a low-impedance ground plane. ~Tom |
#68 |
Trying the LM20333 to get a little more output current capability (3.0 A vs 2.5 A) and I'm also hoping to gain a little more efficiency. The LM20333 has the option of using an external schottky diode in parallel with the synchronous MOSFET. This should yield slightly higher efficiency (--> less heat dissipated).
I just threw the schematic together. I'll need to get crackin' on the board layout and test. ~Tom |
#69 |
Folks,
So thus far I've tried the LM3102, LM20333, and LM22673. The LM3102 and LM20333 are both in 20-pin eTSSOP with exposed DAP that need to be soldered to the ground plane for heat dissipation. The LM3102 is a constant on-time (COT) regulator, the LM20333 is a traditional current mode regulator. As I've reported earlier, the LM3102 is rock solid. But I find it to be a tad marginal for use with, say, a 2A3 that requires 2.5 A for the filament as the LM3102 is a 2.5 A regulator. Hence, I've been on the hunt for a 3 A regulator. The LM20333 is a 3 A regulator. It works just fine, but the ripple voltage on the output is on the order of 30 mVpp (2 A load). The pin-out of this chip is not the most efficient for a 2-layer board layout. Both the input voltage, ground, and switch node are pinned out on both sides of the chip. Hence, the most efficient layout is to route Vin down from one end of the chip and the switch node up from the other end. However, that reduces the thermal path to the DAP to around 5 mm in width. So the chip gets rather hot in normal operation (about 90 C after 30 minutes of delivering 2 A @ 5 V). Granted, I don't have thermal vias in place on my prototype, but still... Then I stumbled upon the LM22673. 3 A output current, TO-263 Thin package with exposed DAP (very hand-solderable), a very intelligent pin-out, and traditional voltage control with internal compensation. What's not to like? So far I like it. After 30~45 minutes running flat out at 2 A, 5 V out, the top of the chip is 45 degrees C. The board and surrounding components are barely above lukewarm. The DC load and line regulation are quite impressive. Here's a brief recap. Attached pictures show the LM22673 schematic, setup, and measured ripple (20 MHz BW). LM3102: Efficiency (12.8 V in, 5 V @ 2 A out): 87.4 % Ripple voltage (5 V, 2 A out): Approx 8 mVpp Line rejection (change in Vout for a 10 V change in Vin): 36 mV (49 dB) LM20333: Efficiency (12.8 V in, 5 V @ 2 A out): 89.5 % Ripple voltage (5 V, 2 A out): Approx 30 mVpp Line rejection (change in Vout for a 10 V change in Vin): 4 mV (68 dB) LM22673 Efficiency (12.8 V in, 5 V @ 2 A out): 90.7 % Ripple voltage (5 V, 2 A out): Approx 6 mVpp Line rejection (change in Vout for a 10 V change in Vin): 1.1 mV (79 dB) Load regulation (change in Vout for a 2.37 A change in Iload): 600 uV (72 dB) For those doing the math at home, the 600 uV change in Vout for a 2.37 A change in the load current amounts to an effective output impedance of 253 uOhm. Yes. uOhm...! And the winner is ..... the LM22673. ~Tom |
#70 |
Nice work Tom!
Would you happen to know what the difference between the LM22673 and the LM2673 is? I designed one with the LM2673 but haven't built it yet. |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Universal Tiger | aged one | Solid State | 238 | 21st March 2020 04:14 AM |
Noisy IC Universal Regulator | dwalker0044 | Power Supplies | 4 | 14th April 2011 03:26 PM |
Parallel vs. series filament supply - or another filament idea | engels | Tubes / Valves | 11 | 13th May 2007 02:06 PM |
New To Site? | Need Help? |
