Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Vendor's Bazaar Commercial Vendors large & small hawking their wares |
Thread Tools |
#961 |
LJM mentions it's OK to use less then +-60v rails and I've got an Onkyo adm21 that I was thinking on using the chassis, heatsink, and transformer. The transformer has 43-0-43, 33-0-33 (not used), 18-0-18, and 5vac. The schematic for this amp shows +-57.8 rails and it uses 2sc5200, 2sa1943 (just one of each for each channel.
Is the L20SE going to live with this much rail voltage? ![]() |
#962 |
I'd like to ask whether the CP1 22uF input capacitor is a part od the negative feedback circuit in those amps?
If the answer is yes, CP1 can't be shorted even if there is no Vdc at the input. I think the answer is YES. |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Irs2092 | luka | Class D | 50 | 15th July 2012 01:48 PM |
IRS2092 AMP help | yaronshani | Class D | 3 | 29th January 2010 02:29 PM |
Irs2092 | gxhcdba | Class D | 11 | 14th December 2009 10:54 AM |
IRS2092 help! | yudi02 | Class D | 2 | 11th October 2009 03:30 AM |
New To Site? | Need Help? |
