Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 7th April 2020, 09:04 PM   #1
ichiban is offline ichiban  United States
It's always something!
ichiban's Avatar
Static discharge on dac, bad sound results!!!
Default Static discharge on dac, bad sound results!!!
Two days ago, while the 9038Pro/Mercury was playing, I touched the volume control knob, volumite, and the playback went to the right channel only. Turning the control all the way counter clockwise gave some left/right playback. I killed power to the whole box, BBB/Hermes/Cronus/9038Pro/Mercury. Re powered and the vol/control functioned normally. This has happened before, static discharge when touching the dac box. So, I discharge my body by touching an unconnected preamp first, forgot this time.
Fired up the system today and thought, this just doesn't sound right/good! Kind of a distorted blurry sound, best I can describe it.
Switched in different amplifiers, no difference.
The clock on the dac board is un-powered, clock comes from the Cronus.
-ICHIBAN
BBB/Hermes/Cronus Twisted Pair Buffalo ESS9038/Mercury into B1Korg into FirstWatt F4 clone
Old 10th April 2020, 01:24 AM   #2
francolargo is offline francolargo  United States
When I first got my 9028Pro DACs working with I2C from the BBB instead of the onboard firmware, I noticed that some settings of the DAC were unstable with static discharges. (I live where static discharges are common in winter.) Fortunately, there was never any permanent damage to the DAC chips. If you use the onboard firmware, however, it is remotely possible that the firmware data was permanently altered by ESD. Perhaps order a new firmware chip from Brian?
Meanwhile, I notice that the new Buffalo DACs sound significantly better when warmed up compared to their sound at first power-on. This is regardless of whether controlled by the onboard firmware or I2C. I warm mine up for an hour or more before making technical adjustments.
Good luck and I hope all are staying safe and well as they enjoy their DIY projects.
Old 11th April 2020, 12:57 AM   #3
ichiban's Avatar
Thanks for the reply.
I may try a new firmware chip.
My Cronus and the DAC board are allways powered on.
The Hermes BeagleBB and Mercury are powered down
when not in use.
I had read somewhere that the clocks work better when
warmed up, so, allways powered.
=-=-=-=-=-= cut =-=-=-=-=-=-=-=
  Reply to this post
Static discharge on dac, bad sound results!!!Hide this!Advertise here!
Plasma discharge vs arc discharge vs flame hellokitty123 Planars & Exotics 17 18th March 2018 03:44 AM
PGA2311 pre-amp static discharge problem activexp Parts 26 4th November 2015 10:47 AM
Static sound from CD? ANOLDSALT Digital Source 6 2nd January 2013 07:01 AM
Static or digital sound by using DAC TBKK Digital Source 12 7th July 2012 02:12 PM
Static Discharge Issues for Zen Amp McJerry Pass Labs 5 26th August 2001 12:41 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
