Hi anyone please help,
having updated my dac from B 11 / Mercury to B 111 se / Mercury it sounds great on s/pdif but I have a lock problem when connecting to my streamer / teleporter for i2s, I get no lock until I touch the teleporter even the lightest touch on an insulated section of the circuit board causes the dac to lock and sound fine. I don't think this is a mechanical issue such as a dry joint as I barley have to touch the board and it was working fine with the B11. Befor the change to B111 there was an Otto between the teleporter and Dac
Many thanks
Steve
Shared album - Steve Preston - Google Photos
Many thanks
Steve
Hi Brian,
Thanks for answering, I don't even need to touch the teleporter just hovering my finger 1mm from the back of the board causes a lock!
Steve
That's capacitance I think. You seem to have built a touch control device
Do you have a ground connection between the DAC and the Teleporter? I only see the three signal lines.
Its my magic touch..........
Only power ground
Steve
Try adding a signal ground and see if that fixes it.
Hi Brian
sorry, where do I conect signal ground on the Teleporter?
Steve
There are ground connection pads next to the output signal pads. Just connect one to the B3Pro input GND pad.
- More Vendors...
- Twisted Pear
- B 111 se upgrade lock problem.
