Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Thread Tools
Old 25th October 2020, 08:15 PM   #11
sbelyo is offline sbelyo  United States
Here are the headers. The should be here next week
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 9th November 2020, 07:10 PM   #12
I'm at the stage where I'd like to start testing the screen. Does anyone have a scrfeenshot of their directory structure. I've never loaded anything to an arduino before
Old 15th November 2020, 04:02 AM   #13
I have both the 4.3 and 5 inch displays working without the shield using the examples and libraries provided by the vendors.
here's the 5" instructions below. The 4.3 is a bit more involved. Buy the shield from sainsmart. They don't bundle it anymore and will tell you it does not work. It does!
4.3" instructions:
On the shield there are jumpers. You must remove the shorts for 5V and apply the shorts for 3.3V
To run a test what you need is here, just follow similaar steps in the 5" instructions:
101-50-150 - [[:Template:SainSmart Wiki]]
5" instructions:
I got the no touch test pattern on the 5" display to work.
For those that are new (myself included), here's what I did.
Download the example file from buydisplay.com.
Extract it and the copy the UTFT folder located in Libraries-Examples_ER-TFTM050-4\Libraries into the Libraries folder in the Arduino folder under My Documents (Windows).
Open the .ino file located here Libraries-Examples_ER-TFTM050-4\Examples\No_Touch_GraphicTest
compile and upload the code
Remove the usb cable from the programming port
Assemble the shield, screen, and arduino together
Plug a 7-12 Vdc 1A or more power source into the power socket on the arduino board
It should display the test
Old 22nd November 2020, 01:43 AM   #14
From the pictures of the working setup it appears you only need the following parts
C2 100n 1206
C3 100n 1206
C4 100n 1206
C10 100n 1206
R1 8.2K 1206
R2 2K 1206 pull-up resistor (optional)
R3 2K 1206 pull-up resistor (optional)
Q1 BC807, BC808 or other equivalent PNP SOT-23 TFT backlight control
U1 24LC256 SO-08 EEPROM chip
U2 Si8605 SOIC-16 I2C Isolator
I will install them tomorrow and then try to get the software working for the 4.3" display first
  Reply to this post
DimDim's TFT HiFiDuino pro projectHide this!Advertise here!
Thread Tools
La Skala Attenuator by Dimdim zgtc Analog Line Level 1 1st January 2019 10:16 PM
DimDim PSU PCBs - give-away ... gentlevoice Swap Meet 2 29th September 2018 03:03 PM
Troubleshooting Buffalo II / HiFiDuino connectivity jonwhitear Twisted Pear 1 29th June 2016 06:10 AM
5.0" Hifiduino Adrculda Digital Line Level 6 3rd February 2013 09:04 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
