Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 22nd July 2019, 03:07 PM   #11
Blitz is offline Blitz  Germany
can you publish your uEnv.txt here ? What type of music do you play pcm, dsd, 2ch ?
Old 22nd July 2019, 08:31 PM   #12
francolargo is offline francolargo  United States
I agree that the output of speaker-test suggests all is well with the BBB but @Blitz's suggestion is a good one.
I see you installed a header on the underside of the Cronus. Is there any chance that the dark gray power input block, which overlaps the back of that header, is shorting any of those pins?
Have we checked directly for an I2S signal coming out of Cronus? If an oscilloscope is not available, perhaps a multimeter set to AC-voltage measuring between ground and Left-right clock (D1?) will show a deflection at the beginning of an 'play' or 'speaker-test' command. That would certainly help isolate the issue.
Finally, I suggest you use the Twisted Pear support site. Take good, detailed images of both sides of all the boards and post them there. Sharp eyes will look for things that are otherwise hard to simply imagine...
Good luck,
Frank
Old 25th July 2019, 09:06 PM   #13
stefanhgm is offline stefanhgm  Europe
Thanks for your replies!
I have no access to the BBB right now, since my Buffalo is at a friends place for trouble-shooting. Why would the uEnv.txt be important?
I play a sound signal for debugging via "speaker-test -Dhw:0,0 -c2" as francolrgo suggested earlier, so I assume pcm, 2ch.
Okay, interesting point. I will test this as soon as possible.
Certainly, that would be helpful to see whether a I2S signal comes out of the Cronus. Unfortunately, we had no oscilloscope to test it. I will try it with a multimeter as you suggested. We also thought about another source of an I2S signal to check whether the Buffalo works correctly. Do you have any suggestion for a source that generates an I2S signal for testing?
Yeah, thats what I think. I asked Brian and Russ to answer in this thread, since all information are already here, but maybe I will try it again at the TP forum. Thanks for this advice!
Old 7th August 2019, 10:27 AM   #14
I verified that there is no connection.
I tried to measure a voltage but unfortunately I could not recognize a difference when starting speaker-test or playing a music file.
As you suggested I opened up a topic in the TP support forum. I also took some Highres pictures that I also attach here. maybe you can spot the problem.
Problems with BBB-Hermes-Cronus for Buffalo-IIIsePro38 build.Hide this!Advertise here!
FS: TwistedPear Cronus-Hermes-Amanero and Legato kits, new unassembled danielkol Swap Meet 7 8th May 2019 03:16 AM
Issue using Cronus/Hermes/Amanero with Soekris DAM1021 DAC MWL168 Twisted Pear 20 24th February 2018 12:55 AM
FS: BeagleBone Black, Hermes, Cronus Thomas Giz Swap Meet 3 18th February 2018 02:32 PM
DSD256 not playing - BBB Hermes, Cronus, B3SE HeadSh0T Twisted Pear 0 8th February 2017 04:04 AM
Twisted Pear: Hermes-BBB Isolator, Cronus + Rhea Re-clocker, Teleporter Transceiver Sabrosa Swap Meet 4 10th January 2017 05:30 PM
Copyright ©1999-2019 diyAudio
