Track Volumite position using a DC meter?
Testing went well last night, and I still have some more tweaks to make.
Basically, you will configure the Volumite to control 1-4 relay driver boards by adding jumpers between Vdd and PB1 and PB3 (on the terminal block). You then set the relay driver's address using it's 3-position dip switches.
Combine this with each driver board powering 1-3 relay boards, and you can control up to 12 channels easily from a single Volumite.
Volumite jumpers:
Code:
No Jumpers:    One relay driver board
PB1 Jumper:    Two relay driver boards
PB3 Jumper:    Three relay driver boards
PB1/3 Jumpers: Four relay driver boards
Relay Driver board dip switches
Code:
Relay Driver Board #1: off-off-off
Relay Driver Board #2: off-off-on
Relay Driver Board #3: off-on-off
Relay Driver Board #4: off-on-on
More details fo follow...
