Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 29th June 2020, 06:47 PM   #91
stephen1212b is offline stephen1212b  United States
unfortunately there are different configurations possible with HDMI.
DCK= bit clock
D1=L/R frame clock or one ch of DSD
D2=Data 2ch PCM or one ch of DSD
don't forget ground
Old 29th June 2020, 06:58 PM   #92
Update: The McFifo is still available and ordered. Thanks for the suggestion it looks like it will be the perfect solution.
The 32 bit limitation is how the built in Mac driver reports the interface in Audio Midi Setup. It may also be a limitation of the firmware that I am running on the Mini DSP MCH Streamer. All Rate does pass 32 bit for 8 channels, but I2s + SPDIF seems to default to 24. Obviously SPDIF is limited to 24 but I am not sure what the other 8 can receive.
Does anyone have a suggestion as to how to verify the bit depth of connection between the mac and the streamer?
Old 29th June 2020, 07:30 PM   #93
wealas is offline wealas
Keep in mind, that when you mix input/output types you are limited to the commonly supported modes by all. Otherwise, the XMOS chip will have to do resampling and clock synchronization which could be very resource intensive (I'm sure it can be done, but I doubt XMOS would write the firmware for it).
Old 30th June 2020, 12:36 AM   #94
angcl is offline angcl  Singapore
DCK= bit clock
don't forget ground
Attachment 856623
but how to connect to HDMI ?
D1>pin 1
D2>pin3
DCK> pin7
Ground > pin5
is this correct ?
thanks
Old 30th June 2020, 12:46 AM   #95
808eengr is offline 808eengr  Europe
808eengr's Avatar
How's your new design Opus illegitimacy?
Old 30th June 2020, 12:51 AM   #96
I am using GUSTARD U16 , USB connect to my computer , need to connect to my B3E .
there is i2S over hdmi behind GUSTARD U16
GUSTARD U16 ES8620 Support PCM32bit/768K DSD512 DOP And Native DSD Di
Old 30th June 2020, 01:21 AM   #97
"HDMI interface (non-standard HDMI interface):
differential I2S signal with LVDS output level"
So one possible solution you would need a teleporter to convert the balanced lvds to the signals you need to feed your dac.
"HDMI" Receiver DAC
bit clock is on 4 and 6 connects to any teleporter pair such as 3 and 6 output from teleporter on 0 and ground to DCK
LR clock is on 7 and 9 connects to any teleporter pair such as 4 and 5 output from teleporter on 1 and ground to D1
Data is on 1 and 3 connects to any teleporter pair such as 1 and 2 output from teleporter on 2 and ground to D2
if running synchronous you will also need master clock on 10 and 12 connects to any teleporter pair such as 7 and 8 output from teleporter on 3 and ground to master clock
Old 30th June 2020, 01:23 AM   #98
Hi Russ and Brian ,
any solution ? or I need to purchase Amanero USB Receiver.
thanks
Old 30th June 2020, 03:15 AM   #99
Attachment 856677
"HDMI" Receiver DAC
this one ?
HiFimeDIY i2s/DSD Isolator 384kHz HDMI to TTL interface – Hifime Audio
Old 30th June 2020, 03:31 AM   #100
or this ?
I2S Input to HDMI I2S LVDS Output Module - Audiophonics
Designing a practical ES9038 based eight channel DACHide this!Advertise here!
FS: Es9038 PRO DAC - Design by Andrea Ciuffoli-Quang Hao Based on the ESS Sabre32 Ref szczemirek Swap Meet 4 3rd July 2017 08:42 AM
I'm designing a TPA6120 based headphone amp, is there anyone can give me some advice shadownee Headphone Systems 13 31st August 2012 04:50 AM
Designing a LM1875-based amp frasco Chip Amps 39 19th January 2012 05:30 AM
Designing a box based on room dimensions StevenLB Subwoofers 1 14th December 2005 08:56 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
