Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 17th January 2019, 10:51 PM   #41
twluke is offline twluke  Japan
B3SE-Pro experimental dual mono firmware.
Default A shell script to control dual mono DACs in pure sync mode via I2C
Hi all,
In addition to a shell script to control B3SEpro DACs in pure sync mode (128fs) via I2C, I prepared another script to control dual-mono B3SEpros in pure sync mode via I2C. A BBB (or perhaps a RasPi) will be required to run this script and, prior to it, you have to confirm that both DACs are well recognized via I2C connection like below (0x48 and 0x49):
Code:
debian@arm:~$ sudo i2cdetect -r -y 1
[sudo] password for debian:
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: 20 -- -- -- -- -- -- 27 -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- 48 49 -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
I'm now listening to the upsampled DSD512 sound by HQ player through the I2C-controlled dual-mono B3SEpros (9028) in pure sync mode and I must say that the sound is really great! You might want to try it if interested.
Old 17th January 2019, 11:03 PM   #42
Blitz is offline Blitz  Germany
This sounds great....I would like to follow your approach, being still on 9018 dual mono...ideally want to run a dual mono 9038 in pure sync with a BBB feeding directly I2S either through Ians Fifo II or chronus...
B3SE-Pro experimental dual mono firmware.Hide this!Advertise here!
DSD256 not playing - BBB Hermes, Cronus, B3SE HeadSh0T Twisted Pear 0 8th February 2017 05:04 AM
New, experimental RPi firmware improves analog out keylimesoda PC Based 2 29th February 2016 08:28 PM
grounding dual mono to mimick a mono block mozarti Chip Amps 5 27th November 2014 10:07 AM
Single Mono's or Dual Mono? Tazzy Pass Labs 8 3rd October 2002 03:03 PM
Dual Mono - Anti Mono Power Supplies pmkap Everything Else 3 16th February 2002 06:10 AM
Copyright ©1999-2019 diyAudio
