Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 31st July 2020, 07:14 PM   #231
francolargo is offline francolargo  United States
Originally Posted by Rubber Soul View Post
I would like to reduce the gain a bit. Do I lower the resistors value on R 1 and 2 (I have 60r now)?
Correct. Measure the replacements and match all 4 as closely as possible. The flexibility to do this is one thing I really like about the Mercury circuit.
Cheers!
Old 31st July 2020, 07:25 PM   #232
Rubber Soul is offline Rubber Soul
Thank you!
Cheers
Chris
Old 1st August 2020, 12:17 PM   #233
minionas is offline minionas  Lithuania
Im contemplating 9038 also instead of mine synchronous clocked 9018 with Paul Hynes local regulators going into mercury. But brightness and agresiveness scares me. Im wondering if burned in 9038 with tridentsr will be like mine 9018 just more resolving and dynamic??
Old 1st August 2020, 07:44 PM   #234
I doubt any of us can answer your question. People actually listen differently so it is very hard to generalize what sounds different vs similar. ...add to that the age-related changes in high frequency sensitivity... OTOH, we do get accustomed to sound signatures of our rigs, and there are so many ways to tweak the sound.
Good luck!
Old 7th September 2020, 02:06 PM   #235
MWL168 is offline MWL168  United States
My new Mercury has been running for 48+ hours now with my dual-mono Buffalo II. I had previously used both Legato and IVY for IV converter.
I tip my hat to Russ and Brian. The Mercury takes my DAC to a different level. The extension, resolution, tone/timber and soundstage all improved.
Because of the similar footprint and all, it was minimal work to substitute the IVY/Legato with the Mercury. I had some additional work due to my dual-Buffalo setup and had to improvise a bit to accommodate the shorter pin headers shipped with the Mercury.
Thanks for a wonderful product!
Old 23rd September 2020, 01:13 AM   #236
stew1234 is offline stew1234  United States
Introducing Mercury - Achieving escape velocity.
Cheers!
I have 4 resistors matched in pairs. Should each matched pair be used on one channel as opposed to the same positions in each l/r channel?
Old 23rd September 2020, 08:05 PM   #237
I would use closest matches within each channel. But hopefully the two matched pairs are also very close in values...
Enjoy!
  Reply to this post
Introducing Mercury - Achieving escape velocity.Hide this!Advertise here!
achieving constant directivity as low as 200Hz using really large drivers? CharlieLaub Multi-Way 53 28th January 2016 10:28 AM
Unconventional Techniques for Achieving Oustanding Stereo Imaging Elias Multi-Way 415 17th February 2014 03:49 PM
Help achieving correct phase response in active 3-way setup pk Multi-Way 2 19th June 2010 08:13 AM
Escape from UK London Blast chris ma The Lounge 2 8th July 2005 05:36 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
