Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 23rd November 2017, 08:16 AM   #11
Nikon1975 is offline Nikon1975  Austria
No black Friday on TwistedPear ? :-)
D.
Old 23rd November 2017, 12:55 PM   #12
Russ White is offline Russ White  United States
Russ White's Avatar
D.
It's not easy being green
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 24th November 2017, 07:40 PM   #13
OK, I pulled the trigger. Now I have to wait for them to arrive.
Question: I have the PSU tuned to 5.2 V. Is it an issue ?
D.
Old 24th November 2017, 07:45 PM   #14
Russ White's Avatar
D.
Technically - it should be okay - but I would just dial it down to 5V.
Audio
Old 24th November 2017, 10:14 PM   #15
Malefoda is offline Malefoda  France
Malefoda's Avatar
Send a message via MSN to Malefoda
D.
The whole pack or just AVCC-SR? Do you have Trident for 3.3 and 1.2V?
Can't wait to read your feedback. Less green light in the night...
Thorens TD-318/Ortofon Super OM 20, Teac VRDS-10, Buffalo II/NTD1, Allo DigiOne/Moode, UCD400, JBL 4313Ti
Old 24th November 2017, 10:19 PM   #16
I already have the trident. The buffalo are part od an opc D1 and of a sen, so both quite transparent
Old 30th November 2017, 07:52 PM   #17
Malefoda's Avatar
Originally Posted by Russ White View Post
Yes the benefits of using SR are very much worth it - the SR has both lower noise and better PSRR. This is particularly important on AVCC - but it helps at all positions. It just sounds nice and clean - noise floor is bottomless. Shunt version of Trident was already very good in these respects - but SR is simply better. They also use less current - which helps your VD supply run more efficiently. In fact I highly recommend people try using the new LCDPS (with the new IC) when using high current demand modules like B3SE-Pro etc...
Russ, no mistake with your low current supply for high current devices?
Btw, do you provide quality "inline pin header" (sorry don't know how to say) fort the 2x 4 pin on the Bxxx? And no start-up delay issue with any BII firmware?
Not sold anywhere in Europe? 20%VAT, import taxes...
Old 30th November 2017, 08:03 PM   #18
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
AVCC 2.1 vs AVCC SR
Well, "low current" is relative. 2A is higher than 1A, but still lower than 5A
Not currently, but I guess I could add those in if people are interested.
There is a slower startup. I have not tested this on a BII, but I *think* a slow AVCC will be okay. Deferring this one to Russ who might know.
Nope, I build and ship them from here (USA) only. Sorry.
Old 30th November 2017, 08:19 PM   #19
Malefoda's Avatar
Thanks Brian!
Old 30th November 2017, 10:23 PM   #20
Russ White's Avatar
I don't think there will be a problem with B-II but honestly I don't have one set up to test - so I can't say for sure.
Audio
AVCC 2.1 vs AVCC SRHide this!Advertise here!
WTB:TPA AVCC 3 module kinku Swap Meet 2 6th May 2017 12:18 PM
AVCC 2.1 - module update Russ White Twisted Pear 136 20th September 2016 05:54 PM
Your AVCC experience Nikon1975 Twisted Pear 6 28th February 2016 10:52 AM
AVCC regulator module merlin el mago Twisted Pear 2 5th March 2011 03:43 PM
WTB BII AVCC module merlin el mago Swap Meet 4 8th February 2011 03:13 AM
