Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 12th April 2019, 05:44 PM   #911
francolargo is offline francolargo  United States
To play SPDIF in asynchronous mode, I'm considering using a switch on the 3.3v input to VDD_XO Trident. This adds about 6" of wire. Would it be advisable to add a bit of capacitance at the Trident input? If so, how much? TIA!
Old 12th April 2019, 06:15 PM   #912
wealas is offline wealas
What do you use for source? The XMOS chips support SPDIF input and can feed the Buffalo MCLK for synchronous operation.
Old 12th April 2019, 06:21 PM   #913
Thanks for the tip. I was thinking of direct toslink to B3Pro, but perhaps another option is available.
Old 12th April 2019, 10:33 PM   #914
drone is offline drone  Germany
Originally Posted by Russ White View Post
So one cool option is that the ES9028/38 allows you to assign GPIOs to SPDIF input. The default firmware could be altered to allow for that - then you could have 2 SPDIF sources (one consumer level coax, and one TTL/CMOS) without needing any external switching. If anyone is interested I can create a branch that does that.
Cheers!
Russ
I would like this firmware branch to use two spdif inputs.
Where to find it?
BR
Branko
Old 13th April 2019, 02:27 AM   #915
Matt Hayward is offline Matt Hayward
Is anybody else getting frequency response changes due to OSF enabled at all?
Old 13th April 2019, 11:16 AM   #916
Never heard of this... The OSF is enabled by default (register 37) and the default filter type is 'fast roll-off, minimum phase' (register 7). How are you controlling the DAC?
Old 15th April 2019, 09:00 AM   #917
jon37bw is offline jon37bw  Germany
Hello
I have seen that the B3se Combo Kit now includes the PSU Centaur and no longer Placid-HD.
This is due to higher current needed by the ES9038 board, true ?
Without using 384fs a Pacid-HD would be sufficient ?
Centaur is not that low-noise - is there any noticeable effect in sound quality ?
BR
Andreas
Old 16th April 2019, 12:31 PM   #918
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Introducing the Buffalo III-SE-Pro 9028/9038
Originally Posted by jon37bw View Post
Hello
BR
Andreas
Yes, the Centaur is for providing higher current, and ease of setup.
All critical sections of the Buffalo are powered by Tridents (or the reg of your choice), which dominate noise performance. They are very low noise, making the pre-regulator noise less of an issue.
While the M350 is not considered "low noise" by today's standards, it is also not "noisy" by any means.
Introducing the Buffalo III-SE-Pro 9028/9038Hide this!Advertise here!
WTB Twisted Pear Buffalo II or Buffalo IIIse charliecola Swap Meet 4 10th September 2016 06:13 PM
WTB : Buffalo III or Buffalo IIIse pw8888 Swap Meet 0 29th March 2015 09:06 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 06:47 AM
Technics ST 9038 Op amps modification Robert64 Analog Line Level 5 21st August 2005 12:11 AM
Technics SH 9038/ST 9038 audio-kraut Analogue Source 0 2nd July 2005 01:53 AM
Copyright ©1999-2019 diyAudio
