Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 29th October 2018, 11:01 PM   #811
barrows is offline barrows
Default maybe...
Originally Posted by itsikhefez View Post
Is there any concern using u.fl cables that are not especially short, something like 100-300mm ?
I have been advised by people who should know, that keeping them 100mm or less is "best". Longer does "work" though...
Old 30th October 2018, 03:17 PM   #812
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Introducing the Buffalo III-SE-Pro 9028/9038
There is no magic length. I2S lines are high-frequency clocks, and have potential to both generate a lot of radiated noise, and pick up interference that muddies the clock signals. Keeping them as short as possible is the key. Shielded u.fl cables can help curb those problems, but the "short as possible" rule still applies.
Old 7th November 2018, 11:28 AM   #813
Killingbeans is offline Killingbeans  Denmark
I'm thinking about building a 9028 + Mercury combo at some point. Would it cause problems, if the PSU, I'm planning to use for the DAC, has a longer start-up time than the one for the I/V stage?
Old 11th November 2018, 06:20 AM   #814
JoeyDD is offline JoeyDD  Canada
Concerning u.fl cables, I was just recently able to finally eliminate a high pitched distorsion that I had in the background when playing DSD through the Buffalo.
I was using the shortest u.fl cables I could (40 and 70 mm), but their diameter was only 0.81 mm. The distortion was gone after I changed them for 1.37 mm diameter cables. I suspect it was mostly the MCLK cables that needed to be thicker (using 90.3168 MHz clock).
Introducing the Buffalo III-SE-Pro 9028/9038Hide this!Advertise here!
WTB Twisted Pear Buffalo II or Buffalo IIIse charliecola Swap Meet 4 10th September 2016 07:13 PM
WTB : Buffalo III or Buffalo IIIse pw8888 Swap Meet 0 29th March 2015 10:06 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 07:47 AM
Technics ST 9038 Op amps modification Robert64 Analog Line Level 5 21st August 2005 01:11 AM
Technics SH 9038/ST 9038 audio-kraut Analogue Source 0 2nd July 2005 02:53 AM
