Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 9th September 2018, 01:23 AM   #741
ichiban is offline ichiban  United States
It's always something!
ichiban's Avatar
Introducing the Buffalo III-SE-Pro 9028/9038
You mean the four 2x2 connectors I circled with red? Where do I have to connect the external battery then?
Yes that 2x2 connector must connect to the BBB for the battery
to protect the BBB on shut down.
Battery goes into the connector next to where you have the 5v
external ps currently wired in. Do be mindful of + - connection.
To be honest tho, I had the battery connected where you have yours
now. I think the two are linked, as I recall. I later opted to use the
connectors which made it easy to remove the battery if needed.
Currently listening to F6/w curve matched SemiSouth outputs
Old 9th September 2018, 07:57 AM   #742
stefanhgm is offline stefanhgm
Originally Posted by bk856er View Post
Confirmed dead boards, or just funky LED behavior?
The BBB does not start up/blink or anything with the mini-USB power adapter I used to power it so far. So, I considered it destroyed.
The Hermes LEDs do not work anymore. If a working BBB would be necessary to light up this four LEDs this could be due to the broken BBB. If the four LEDs should work without the BBB then the Hermes could also be damaged .
Q1. So, should the Hermes LEDs also work without a BBB connected?
Q2. Any other suggestions I can ensure the Hermes or BBB or even the other boards are not dead?
now. I think the two are linked, as I recall. I later opted to use the connectors which made it easy to remove the battery if needed.
Thanks for this info. Yes I have seen people connect the battery where I did. I guess my next run with a new BBB would be completely without battery first.
Q3. For me it seems the (maybe wrongly connected) battery was not the problem for destroying the BBB(/Hermes). Any other suggestions of what I should check that could have caused my problems?
Thanks for your help guys!
Old 9th September 2018, 08:45 AM   #743
Luca72c is offline Luca72c
Maybe, if the problem was at switch on and not at shutdown. But, if you didn't solder the square 4 pin connectors to hermes and BBB, where did battery current go?
May it have caused some other power problems?
Russ is needed to answer that...
About Q1, i cannot answer because i never tested hermes without BBB. Russ is needed for this answer, too...
And most of all, a clear, comprehensive, concise, step-by-step user guide is strongly needed for these products too, considering it was longly expected...
Old 13th September 2018, 02:34 PM   #744
hellokitty123 is offline hellokitty123  United States
I have a question about the design of the DAC. I've noticed that DGND and AGND are connected to the same plane at the same central location.
Isn't this bad practice?
Old 13th September 2018, 02:42 PM   #745
Russ White is offline Russ White  United States
Russ White's Avatar
Absolutely not - a solid ground plane is ideal for this type of layout. I have been designing/building/measuring/optimizing this stuff for a long time BTW - this is not new to me.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 13th September 2018, 11:47 PM   #746
itsikhefez is offline itsikhefez  United States
I am using an amb sigma11 (at 4.88V) to power the Buffalo.
Is it OK to use it to power the Chronus as well?
I am using the 9V transformer from TPA and the s11 does not have any built-in current limits.
Old 14th September 2018, 02:37 PM   #747
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
If it can supply the current, sure. You could even tap power for the Cronus from the Buffalo's I2C header if that offers better wire routing.
Old 15th September 2018, 09:31 PM   #748
Russ, Brian could someone of you please answer my questions?
Old 21st September 2018, 04:16 PM   #749
Russ White's Avatar
It would be best to post this in the Hermes-BBB thread.
This thread is not on that topic.
That said - you would definitely need to have a BBB connected to see much happen unless you send signals yourself.
The design is open source - you can see the schematic and test those points yourself if you like.
Cheers!
Russ
Audio
Old 21st September 2018, 04:28 PM   #750
Microfast is offline Microfast  Italy
Some news on the multichannel Es9038pro board or it is a cancelled project?
Introducing the Buffalo III-SE-Pro 9028/9038Hide this!Advertise here!
WTB Twisted Pear Buffalo II or Buffalo IIIse charliecola Swap Meet 4 10th September 2016 07:13 PM
WTB : Buffalo III or Buffalo IIIse pw8888 Swap Meet 0 29th March 2015 10:06 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 07:47 AM
Technics ST 9038 Op amps modification Robert64 Analog Line Level 5 21st August 2005 01:11 AM
Technics SH 9038/ST 9038 audio-kraut Analogue Source 0 2nd July 2005 02:53 AM
