Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 6th August 2018, 02:34 PM   #701
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Introducing the Buffalo III-SE-Pro 9028/9038
Originally Posted by stefanhgm View Post
1. Related to the connection between Cronus and the Buffalo board. There are 2x12 connection pins, but I only got two 2x10 female connector. I will just cut one apart to build my own additional 2x2. Its correct to connect all 2x12 pins, right?
The 2x10 header is designed to mate directly to the 2x10 header on the older 8-Channel Buffalo. You do not need to use it at all for the Buffalo-III Pro.
2. Are the two 3,3V regulators identical? So, the connectors DCVV and VDD_XO are interchangable?
They are identical.
3. Is there anything else except the male header to connect to the regulators? There are additional contacts and I saw soem pictures with LEDs.
No, just the 3-pin header. The LEDs were on older versions of the Tridents.
4. Are the connectors LOCK and A_MUTE on the Buffalo board intended for the two LEDs? Can I use them to show that the Buffalo is powered on at the case? Or which one am I supposed to use for that purpose?
They are for the LEDs. Neither one will indicate power specifically, but one or the other will be on in regular use. For power indication, I would tap power from your power switch or a power supply rail.
5. Is it a common choice to use the volume poti at the Buffalo? I think controlling the volume via software and at my amp will suffice or am I missing something?
The digital volume control of the ES90x8 DAC will give you the best performance. You can certainly control volume in other ways, depending on your system. If you do not use the volume control, be sure to use the included shunt jumper on the three pin header, which effectively sets the DAC to full-scale output.
Old 6th August 2018, 02:38 PM   #702
The line on the cardboard marks the front border of the case. The piece of newspaper is the missing Placid HD BP Power Supply. And there still needs to get an SSD in there for storing my music. I want to put it below the beagle board. What do you think about these two setups? Is it a problem to stack the transformers?
You will probably want to spin the DAC around to keep I2S signals as short as possible.
Keep in mind that the magnetic poles from toroidal transformers radiate with the axis of the hole, so "aiming" them at your circuit boards (second picture) will result in more risk of noise (still very low risk). There is no issue stacking them, per se, but it may result in more heat (again, low risk).
Old 8th August 2018, 07:15 AM   #703
itsikhefez is offline itsikhefez  United States
I want to add Sample rate to the firmware on the `WithDisplay` branch.
It looks like its a matter of reading R66-69 and deriving it from there?
Besides that, what is the recommended workflow for developing firmware for the Buffalo?
I cloned the repo and loaded it into AtmelStudio and it builds fine.
Is there a way to simulate the Buffalo board in order to debug and step through the code?
Old 13th August 2018, 09:33 AM   #704
Goto is offline Goto  United Kingdom
Well, I finally got the Amanero/Hermes/Cronus working (thanks Brian) and have it interfaced to the Buffalo-iii-SE-Pro/Mercury. Operation is sync using the 128fs firmware.
So I can give my full, considered review of this dac now, taking direct feed from the SE outputs into my Focal Utopia headphones which are pleasingly easy to drive.
It's stunning. Thanks TPA.
Old 13th August 2018, 06:09 PM   #705
Russ White is offline Russ White  United States
Russ White's Avatar
It's kinda tricky in PureSunc mode - because you don't have a single master clock. You would need to pass that info to the controller (what clock base is being used).
I develop firmware mostly on my mac and use homebrew to install "osx-cross/avr/avr-binutils" and " osx-cross/avr/avr-gcc"
I tend to use Eclipse IDE with CDT and AVR support.
I am not aware of a way to simulate an ES9028/38 - but hey that would be cool. I use an i2C analyzer or display etc and echo back info debugging.
Cheers!
Russ
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 13th August 2018, 06:10 PM   #706
Russ White's Avatar
Thank you! So glad to hear that! Enjoy!
Cheers!
Russ
Audio
Old 15th August 2018, 05:56 AM   #707
sbobba is offline sbobba  Italy
Send a message via AIM to sbobba Send a message via MSN to sbobba Send a message via Yahoo to sbobba
Default digital volume control of the ES90x8 DAC
Hi Brian, I would like to replace with a better quality digital volume control potentiometer that I found in your kit. Your is linear from 4,7Kohm and in my surplus I have an excellent linear 10Kohm. I think it may be fine anyway, but I prefer your opinion. Thank
Old 15th August 2018, 04:26 PM   #708
That should be fine. It is simply acting as a voltage divider. I would not go beyond 10K though.
Old 15th August 2018, 04:27 PM   #709
Russ White's Avatar
That pot is not in the signal path at all - it forms a voltage divider that used only seen by the controller ADC. The volume control itself is purely digital in the DAC itself based on a register. Changing the pot will have absolutely no effect on the audio signal.
Still you can use any pot you like 2K to 10K should be OK. Just please don't expect any audible changes - because no audio signal is presented to the pot - ever.
Cheers!
Russ
Audio
Old 20th August 2018, 09:46 AM   #710
Do the LED's have to be soldered in order for the Buffalo to work properly, or can they be omitted?
Introducing the Buffalo III-SE-Pro 9028/9038Hide this!Advertise here!
WTB Twisted Pear Buffalo II or Buffalo IIIse charliecola Swap Meet 4 10th September 2016 07:13 PM
WTB : Buffalo III or Buffalo IIIse pw8888 Swap Meet 0 29th March 2015 10:06 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 07:47 AM
Technics ST 9038 Op amps modification Robert64 Analog Line Level 5 21st August 2005 01:11 AM
Technics SH 9038/ST 9038 audio-kraut Analogue Source 0 2nd July 2005 02:53 AM
Copyright ©1999-2019 diyAudio
