#1021 | |
#1022 |
Hello All,
With amanero in slave mode, does VDD_XO need to be omitted and EXT_MCK from Buffalo III SE Pro connected to U_MCK in Cronus Reclocker (with Rhea modules installed)? |
#1023 | |
My original design was to be able to use the 100MHz onboard clock with SPDIF, versus an external MCLK with I2S. I'm not succeeding in getting the old 9018s configured via I2C to work with the consumer level SPDIF from the TPA Toslink board. Toslink signal integrity doesn't seem bad (though only 375 mv p-p when connected to the B3, concern?), clock oscillations look good, and I2S is confirmed shut off. Is there still any online info concerning the 9018 register settings from the old B3 stock EPROM? Many TIA, Frank Last edited by francolargo; 12th January 2021 at 03:59 AM. |
#1024 | |
![]() Quote:
1. with the Trident in place for VDD XO, and no u.fl cable for the master clock from the Cronus. This uses the ESS chip in asynchronous mode, and resamples all data asynchronously. 2. Without the Trident in place for VDD XO, and with the u.fl cable in place from the Cronus for the masterclock. This runs the ESS chip in the synchronous mode and resamples data synchronously. My opinion is that synchronous mode sounds better, but of course you can try both methods and decide for yourself what you prefer. |
#1025 |
Barrows,
Can you use synchronous mode with the standard Twisted Pear firmware? |
#1026 |
Yes, I do so all the time. Basically, the DPLL will just "freewheel" as the master clock and bit clock will be synchronous, so the result will be no asynchronous re-sampling. The only drawback is that the ESS chip will no longer "reduce" jitter, but with the Cronus/Amanero this should not be a concern, as this is a very low jitter source.
#1027 | |
The reason why I ask is sporadic static-like noise I have in both modes, sync & async with DSD. With PCM 352800 Hz in sync mode no sound at all. In async mode there is a lot of noise instead of sound. All other sample rates are good. Not sure why... maybe I have to get rid of u.fl cables? |
#1028 | |
Full disclosure: "Largo" is a family joke meaning "from the minds of imposters". ![]() |
#1029 | |
#1030 |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
WTB Twisted Pear Buffalo II or Buffalo IIIse | charliecola | Swap Meet | 4 | 10th September 2016 07:13 PM |
WTB : Buffalo III or Buffalo IIIse | pw8888 | Swap Meet | 0 | 29th March 2015 10:06 PM |
Buffalo Dac original vs Buffalo II | mrtakib | Digital Line Level | 7 | 24th August 2010 07:47 AM |
Technics ST 9038 Op amps modification | Robert64 | Analog Line Level | 5 | 21st August 2005 01:11 AM |
Technics SH 9038/ST 9038 | audio-kraut | Analogue Source | 0 | 2nd July 2005 02:53 AM |
New To Site? | Need Help? |
