Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Thread Tools
Old 15th January 2021, 07:35 AM   #211
marcin1qaz is offline marcin1qaz
Default Hermes / Cronus compatibility with the new Amanero Combo384SE
Hello, greetings to everyone from Poland.
I have a question. I would like to purchase a Hermes / Cronus combo for Amanero. I already have a new version of Amanero Combo384SE, equipped with SPDIF. SPDIF is on a separate connector, but pinout on the main Amanero connector are slightly different too.
Will this be a problem if I mount Hermes / Cronus on it?
Please see, here is specification of both:
standard: http://www.amanero.com/drivers/combo384-D.pdf
new: https://www.amanero.com/drivers/combo384SE.pdf
Old 14th March 2021, 12:28 PM   #212
kachel is offline kachel  Netherlands
Hi! After some initial setup issues (see my posts in Cronus thread, for this issue I think this thread is more appropriate) I am able to run 44.1x multiple audio without a problem. 48x audio sounds lower pitch, it is not using the correct clock.
Findings:
Pin 11 on the Amanero never changes to 3.3v, it stays at 0 no matter the audio sample.
This is my setup:
Volumio -> Amanero -> Hermes -> Cronus =>2x Teleporter => 2x B3SE
My flashing process (running Windows in Parallels on Mac):
1) Plugin USB
2) Clear flash on Amanero
3) Replug USB Amanero
4) Flash CPLD
5) Replug USB Amanero
6) Flash CPU
7) Replug USB Amanero
8) Flash configuration bits
In the Cronus thread I was told to put a jumper on HMCK_SEL, what does this jumper do? I do not get sounds when doing that.
I have tried a couple different firmware settings.
Slave_For_1080 && jumper on HMCK_SEL
No sound for any frequency
Slave_For_1080 && no jumper on HMCK_SEL
Proper sound for 44.1x music. Slow sound for 48x music.
Cpld_For_1080 && configuration set && (jumper on HMCK_SEL || no jumper on HMCK_SEL)
Sound on all music, however no change on pin 11 (stays at 0).
I currently run the last config, but I think this uses the clock from Amanero. What can this be? Maybe the config bits aren't set properly? Can I check this?
For 44.1x music it sounds really good. I had not expected it to be such a big difference from WaveIO thanks for such a great product!
Old 14th March 2021, 04:36 PM   #213
I now see in the manual I forgot a step, after flashing CPLD you need to unplug&replug the USB, wait 4 seconds, take it out and put it back again. I did that just now but that didn't make a difference.
And as a test I also set pin 1 to clock selector and see if that would change when playing different files. It does not.
Old 15th March 2021, 02:50 PM   #214
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Introducing the Hermes-Amanero
It really seems like the flags are not being set, but not sure why, as it sounds like you are setting them.
File Type: png Screen Shot 2021-03-15 at 10.49.20 AM.png (13.0 KB, 75 views)
Old 15th March 2021, 03:24 PM   #215
Weird right? That's what I did, it says 'Flash Updated'.
Should pin 11 change voltage when paused or playing after just flashing CPLD and CPU without setting the config bits? It does not do that.
Old 23rd March 2021, 06:35 PM   #216
It’s working! Finally! Turns out even though Windows detects the Amanero and flashing works and the tool says ‘Flash updated’, the configuration bits are only set when you also install the driver.
Thanks Brian for pointing me in the right direction!
Old 23rd March 2021, 07:07 PM   #217
You mean that you need the Amanero Windows driver installed before the software can set the flags? That makes sense, I think this can help others with the same problem.
Old 23rd March 2021, 07:47 PM   #218
Yes that's what I mean you need the driver to set the config bits. It worked after I installed the driver and set the config bits.
BTW I'm running DSD512x48x44 firmware with Slave_for_1080.
  Reply to this post
Introducing the Hermes-AmaneroHide this!Advertise here!
Thread Tools
Hermes-BBB/Botic cape for BeagleBone Black Russ White Twisted Pear 660 2nd September 2020 10:03 AM
WTB: amanero board janos_904 Swap Meet 7 10th May 2015 10:50 AM
WTB: Amanero ristar Swap Meet 5 5th December 2014 07:55 AM
amanero merlin2069er Swap Meet 3 19th April 2014 09:32 PM
WTB - Amanero ThuyTN Swap Meet 0 31st January 2013 10:21 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
