Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 21st September 2018, 03:33 PM   #181
Russ White is offline Russ White  United States
Russ White's Avatar
If you use the settings on the first post you should be just fine. Just make sure Cronus is powered up before you connect USB to source.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 21st September 2018, 06:45 PM   #182
stephen1212b is offline stephen1212b  United States
I have several projects underway at the moment. The simplest is adding a sub to my existing system. Crossover, volume, and delay handled upstream by plugins to pure music.
1. The Mac OS allows the creation of a virtual interface made of separate interfaces. Currently an Amanero and the built in mini digital output. However the Mac doesn't seem to recognize two Amanero boards at the same time. Thoughts?
2. I also notice that there is a 4 channel version of the firmware available for the Amanero. That may be the best solution for 4 channel audio. Has anyone tried it?
Old 24th September 2018, 06:30 PM   #183
Russ White's Avatar
Have not tried it - but i can say that the Hermes-amanero is not designed for anything but stereo use. It only passes one data signal for PCM.
Cheers!
Russ
Audio
Old 25th September 2018, 09:01 PM   #184
Apparently you give up the ability to pass DSD but I only listen to PCM so no worries there. The second PCM data appears on the DSDOE line. Is this the signal that normally passes unisolated through the Hermes to the Cronus to switch between PCM and DSD, or is this signal just ignored not even passion through the Hermes? If it is the flag to switch modes would I pull it up or down to permanently select PCM? My thought would be to feed a teleporter substituting the DSDO (new PCM data) for the standard Data line. The sub would then have its own isolated I2S but without the benefit of reclocking unless there would be a way to add a second cronus?
The perhaps less risky way would be to simply use a second Amanero and combine the two interfaces as an aggregate in AudioMidi on the MAC. Unfortunately a second Amanero isn't recognized. Has anyone changed the name and ID of an Amanero and been able for multiple interfaces to be recognized?
Old 25th September 2018, 09:16 PM   #185
Russ White's Avatar
Only 4 signals are passed outbound and only 3 re-clocked - Clock Select (pin 11) - BitClock - LRCK/DSD_D1 - PCM_DATA/DSD_D2.
So you would basically need a purpose designed Hermes module
Changing the ID Amanero is a promising idea. I would try that next.
Audio
Old 11th January 2019, 05:10 PM   #186
powermike145 is offline powermike145  United States
Default Hermes Outputs
What are the output header pin labels for the Hermes board? I don't want reclocking, just the Amanero and isolation. So I have an Amanero and a Hermes board. The Amanero outputs are labeled but Hermes isn't. I guess most people use the Cronus board with this package for reclocking and therefore use Cronus's outputs.
For my DAC all I need is the Bit clock, LR clock, data, and GND along with isolated 3.3V and GND. Which pins are these on the Heremes output? Thanks in advance, for any help.
Old 12th January 2019, 03:49 PM   #187
smanz is offline smanz  Spain
Hermes-BBB/hermes-bbb-schematic.pdf at master * twistedpearaudio/Hermes-BBB * GitHub
Output connector pinout of Hermes BBB and Hermes Amanero is the same.
Antonio
Introducing the Hermes-AmaneroHide this!Advertise here!
Hermes-BBB/Botic cape for BeagleBone Black Russ White Twisted Pear 632 13th October 2018 08:16 PM
WTB: amanero board janos_904 Swap Meet 7 10th May 2015 11:50 AM
WTB: Amanero ristar Swap Meet 5 5th December 2014 08:55 AM
amanero merlin2069er Swap Meet 3 19th April 2014 10:32 PM
WTB - Amanero ThuyTN Swap Meet 0 31st January 2013 11:21 AM
Copyright ©1999-2019 diyAudio
