Hermes-BBB/Botic cape for BeagleBone Black
I have some trouble playing dsd files with bbb/ Hermes/Cronus (45/49 clocks)
Playing pcm at 384 kHz gives stable lock at dpll setting lowest.
But dsd 64 has every 1-2 seconds no lock. DSD 128 even more unlocks and intermittent hissing sound. Only if I set dpll to highest I get stable lock.
Thought was problem with teleporters I use. But also with direct connection via short uFl cable problem is the same. Checked al power rails while playing Musik and everything is ok.
Any advise? How much is impact of dpll settings?
BR
Branko
