Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 17th October 2019, 03:38 PM   #851
barrows is online now barrows
Felipe, if you Google for information on firmware flashing for Amanero you will find some instructions. Thanks for the offer, my GF is around with her Windows machine often enough that I can change the firmware if I need to, it has just been awhile since I did it last. But I do not recall needing to change the settings much, if at all, just the main firmware and the CPLD for slave, or not. I do not worry about DSD swapped or not, as I only send DSD, so I can swap the u.fl to make sure channel mapping is correct.
Old 17th October 2019, 03:40 PM   #852
merlin el mago is offline merlin el mago  Europe
merlin el mago's Avatar
Thanks barrows, I flashed several units, I guess I only need to change the CPLD & CPU as you suggested.
Old 17th October 2019, 08:38 PM   #853
rowli is offline rowli  Sweden
Hi Merlin,
when you have flashed the SLAVE_1081/2006be10
change the configuration bits as in this picture
Introducing the Hermes-Amanero
Ps: when you flash configuration bits. If it says "audio device not recognized" instead of "OK", then replace the PID 071a ⁣with PID 0a23 on the editbox on top of the Configtool window"
regards Micke
Old Yesterday, 12:55 PM   #854
@barrows & Micke
Domenico from Amanero advice:
You can use F0 to select the clock 22 or 24 in this way you don't need to assign the configuration Bits.
But if you use only 22 you can do it without clock selector so no needs to change bit configuration.
Best,
Dom
Old Yesterday, 03:01 PM   #855
As I recall mine are set as in the picture, and I appear to have no issues with both 1099rc and 2006be, both with slave 1081 for use with the Cronus.
For the DSC-2 I will be using an adapter (with isolation) which allows me to get the mute signal directly from the Amanero board (isolated on the adapter) so I do not have to reconfigure anything to get mute through the Cronus' output.
The BuffaloPro does not need Mute, as the DAC itself is seems to be well behaved in this regard. But, i am always sending only DSD 256, so I do not have to worry about problems caused by sample rate switching.
Old Yesterday, 03:15 PM   #856
I'm also always sending only DSD256.
Cronus - It's about time.Hide this!Advertise here!
Long Time DIYer, first time poster... greglenz Introductions 2 4th September 2014 02:01 AM
long time audio, first time hifi tastie Introductions 7 12th December 2012 01:02 AM
Long time listener, first time caller. cihtog Introductions 5 15th April 2012 12:05 AM
First time caller, long time listener... smallangryboy Introductions 15 19th March 2005 08:10 PM
is doing time alignment now a waste of time? Beggar Multi-Way 9 28th July 2003 05:45 AM
Copyright ©1999-2019 diyAudio
