Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Thread Tools
Old 4th October 2015, 05:37 PM   #361
Russ White is offline Russ White  United States
Russ White's Avatar
Originally Posted by schultzsch View Post
is normal that when I connect the b3se in sync mode with the cronus and turn off the reclocker(SW2:4) I get lower frequency attenuation and a sound like the speakers were 180 degrees phase inverted ?
Something is definitely screwy. Likely you are misinterpreting the switch states? Maybe post on the support forum with good pics of the switches etc.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 4th October 2015, 05:39 PM   #362
Russ White's Avatar
tested again today for stereo imaging and discovered that the dac goes into mono(left channel) when I turn the reclocker off
also the spdif autodetect bypass seems to change the sound with a lower rolloff for the top end.
what I am doing wrong?
edit: when using spdif bypass it won't play dsd
I don't know what you mean by reclocker in this context - do you mean the jitter reduction (ASRC) in the ES9018 DAC itself?
You don't generally want to turn it off unless you also turn off the OSF.
Audio
Old 4th October 2015, 05:41 PM   #363
Russ White's Avatar
Originally Posted by kencmh View Post
For the Cronus Re-clocking Module, if I already got a master clock, do I still need the Rhea Pair? Which socket should I connect the master clock? If purchase the Rhea pair as well, will the master clock override the Rhea pair if a master clock is connected?
Just wanted to check before placing my order.
What sort of mast clock are you talking about?
Audio
Old 4th October 2015, 09:02 PM   #364
schultzsch is offline schultzsch  Europe
Yes, asrc of es9018.
When I bypass the reclocker(SW2:4) it doesn't bypass the oversampling filter also?
Old 5th October 2015, 03:47 AM   #365
kencmh is offline kencmh  Hong Kong
Like the Apogee Big Ben Master Clock
Old 19th October 2015, 07:54 PM   #366
dwjames is offline dwjames  United Kingdom
dwjames's Avatar
Am I right to assume that the vd power supply input to the cronus is the raw supply for on board voltage regulators? What range of input voltage can it safely receive?
Thanks,
James
Old 20th October 2015, 06:10 AM   #367
5 to 7 vdc
Old 28th October 2015, 09:18 PM   #368
dwjames's Avatar
5 to 7 vdc
thanks
Old 24th November 2015, 11:11 AM   #369
ijscobar is offline ijscobar  Netherlands
Banned
Posted this also in the TPA support forum but would like to post it here too.
My B3SE is has the Cronus-Hermes-Amanero stack. Had some trouble but that was all solves (I think). So I decides to put the top on my chassis and therefor I had to put in an other, shorter, usb cable to the back side of the cabinet. I forgot I had removed the bolts between Cronus and Hermus. Result was no sound. I re-soldered the headers of both Cronus and Hermes and there was music again.
Funny thing is that low resolution files play normal as they should. But higher resolution files play for a while, then start to stutter en finally no sound at all.
When this happens the Lock Led on B3SE starts to flicker and then goes out...
Anybody any idea what's happening?
SPDIF is working at all sample rates...
Old 24th November 2015, 12:54 PM   #370
Russ White's Avatar
Typically this means something is changing over time. Likely a supply running out of current causing low voltage. Check shunt currents etc - especially the 1.2V (add 27R at R4 to get more current if needed) trident on B3SE.
Audio
Cronus - It's about time.Hide this!Advertise here!
Thread Tools
Long Time DIYer, first time poster... greglenz Introductions 2 4th September 2014 02:01 AM
long time audio, first time hifi tastie Introductions 7 12th December 2012 01:02 AM
Long time listener, first time caller. cihtog Introductions 5 15th April 2012 12:05 AM
First time caller, long time listener... smallangryboy Introductions 15 19th March 2005 08:10 PM
is doing time alignment now a waste of time? Beggar Multi-Way 9 28th July 2003 05:45 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
