Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Thread Tools
Old 24th April 2015, 02:14 PM   #101
deanoUK is offline deanoUK  United Kingdom
Cronus - It's about time.
Default MiniDsp USBSTREAMER - lock problems.
Originally Posted by Microfast View Post
I have not stable lock problems with the MiniDsp USBSTREAMER used with the buffalo III setted in mch ...
Marco
The MiniDSP USBStreamer has a LOT of jitter on its I2S outputs.
Try turning off oversampling on the Buffallo III. Perversely , This worked for me.
I also have another setup with a MiniDSP USBStreamer outputting 8 channels isolated and synchronously clocked.
But it requires some surgery on the board.
I intend to replace my current isolator/re clocker lash up with BBB-Hermes and Cronus as soon as I have time.
Will post the details in you new thread if you are interested (?).
Old 24th April 2015, 07:30 PM   #102
Microfast is offline Microfast  Italy
Originally Posted by Russ White View Post
The USB Streamer does not send a clock select signal nor accept a master clock - so it would not be a great fit for cronus. While it would work - because you would be mixing time domains you would get data loss and errors. It would not be bit perfect.
If you want a bit perfect USB solution then you could get the Hermes-Amanero + Cronus.
Cheers!
Russ
Hi Russ,
But is the Hermes-Amanero+Cronus solution, multichannel?
Marco
Old 24th April 2015, 07:34 PM   #103
Thanks for the advise, curiosly, I was arrived to this some hours ago; so now it works ...
However exactly like you say the USBSTreamer interface has some problems and limitations.
This way I am interested to alternative solutions ...
For start I am waiting the Rigisystems USBPal that seems be a better solution.
I will read for sure your work ...
Thanks and regards
Marco
Old 24th April 2015, 09:29 PM   #104
Russ White is offline Russ White  United States
Russ White's Avatar
I am not familiar with the USBSTreamer - but if you can get access to the master clock you could actually devise a way to make it work with Cronus. PM me if you interested to try it.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 26th April 2015, 11:34 PM   #105
Russ White's Avatar
Is there any interest in a Cronus/B3 to Teleporter adapter?
You would use one at the Cronus with a teleporter connected to J2, and another connected to a B3 with teleporter connected to J3. In this situation the Cronus powers it's teleporter - and the B3 powers it's teleporter (both with 5V)
For those not using B3 you would just use the one at the cronus and then just direct wire the teleporter to the DAC.
The adapter is wired to transmit MCK, DCK, D1, D2 from cronus.
Audio
Old 27th April 2015, 12:58 AM   #106
bk856er is offline bk856er  United States
bk856er's Avatar
I'd be down for some Teleporter adapters.
BK
Old 27th April 2015, 03:17 AM   #107
pixelpusher is offline pixelpusher  United States
Using Teleporters is one of the options I have been considering. I thought you could just hook up the I2S wires but if an adapter makes it easier I would certainly be interested.
Old 27th April 2015, 07:05 AM   #108
picovolt is offline picovolt
I've been thinking more and more about a pair of teleporters; this certainly solves my "where to fit all this in my existing enclosure" dilemma. Plus, it would allow the BBB-TP appliance more flexibility. An adaptor board that keeps the i2s lines as short as possible seems ideal.
Old 27th April 2015, 07:35 AM   #109
druidaudio is offline druidaudio  Wales
Yes please!
Old 27th April 2015, 01:40 PM   #110
Russ,
Would this adapter work with the switch you mentioned earlier? I would like to run both an Amanero USB and the BBB to the Teleporter.
Cronus - It's about time.Hide this!Advertise here!
Thread Tools
Long Time DIYer, first time poster... greglenz Introductions 2 4th September 2014 02:01 AM
long time audio, first time hifi tastie Introductions 7 12th December 2012 01:02 AM
Long time listener, first time caller. cihtog Introductions 5 15th April 2012 12:05 AM
First time caller, long time listener... smallangryboy Introductions 15 19th March 2005 08:10 PM
is doing time alignment now a waste of time? Beggar Multi-Way 9 28th July 2003 05:45 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 13.64%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
