Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Thread Tools
Old 1st July 2021, 03:49 PM   #3181
spresto9 is offline spresto9  United Kingdom
Hi Frank, you are a gent.
here is the output, seems still to be 32bit
New startup file
Cheers Steve
Old 1st July 2021, 08:58 PM   #3182
francolargo is offline francolargo  United States
Ah - yes ALSA is using S32_LE, but the data between 24 and 32 bits should be zeros. If the system is working to plan then I wouldn’t bother further. You can direct ALSA to output S24_LE but it is quite easy to muck things so that no usable signal results. I would want to pre-test any modification advice I gave but that can’t happen in the near future. [I'm completely remodeling a remote lake cabin.]
Old 2nd July 2021, 07:27 AM   #3183
Thanks again Frank for the explination
I'll start looking for other reasons why the transceiver is not working now,
I wish I had time to learn a lot more of this stuff.
Good luck with the remodeling, take it easy in the heat!
Steve
Old 2nd July 2021, 02:20 PM   #3184
Ha, cracked it, i was editing the wrong file!!
output now showing :-
format: s24_le
Steve
  Reply to this post
Support for Botic Linux driverHide this!Advertise here!
Thread Tools
Open baffle with fullrange driver and bass support Godzilla Full Range 5 22nd July 2011 01:32 PM
Low end support for single driver monitors strider75 Multi-Way 97 30th September 2009 03:02 PM
ASIO support (driver) for Labview Aoxomox Digital Line Level 0 3rd May 2009 05:29 PM
Linux/BruteFIR support coming in LspCAD tcpip Multi-Way 18 18th October 2005 03:08 AM
linux badgers Introductions 3 3rd April 2005 03:27 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
