#3141 |
To my understanding the concepts of clock master and slave apply to the bit clock and frame sync only. For botic it is always assumed that the MCASP is the master for this and not the codec. Indeed the DAI format setting specifies the master / slave configuration between codec and platform as well as other settings and I would assume it needs to be changed for TDM mode.
With regards to the audio master clock (which is divided down to generate the different signals), the botic driver I maintain currently only supports the default configuration of a Hermes - Cronus combination where two different clock frequencies are available on one signal input which can be switched by a GPIO. Alternative configurations that used to be supported with earlier versions of the driver have not been implemented mainly because I do not use them. Regarding clocks these alternatives are: - Using only the BBB internal clock for 48k based frequencies (this means no playback / too fast playback for 44.1k based material) - Using the internal BBB clock together with one external clock for 44.1k Happy to re-integrate them based on the rewrite of the machine code driver if someone would be willing to put some initial effort into it. |
#3142 |
Actually the DAI format setting would not necessarily need to be changed for TDM mode...
#3143 |
Thanks for the insights into the botic clocking design. As I mentioned, I'm a noob when it comes to ASOC driver design and clocking. I tried the following changes:
Code:
Index: git/card/botic-card.c =================================================================== --- git.orig/card/botic-card.c +++ git/card/botic-card.c @@ -23,6 +23,8 @@ static int dai_format = SND_SOC_DAIFMT_C static int blr_ratio = 64; +static int clk_master = 0; + struct botic_priv { unsigned long clk44_freq; unsigned long clk48_freq; @@ -66,12 +68,12 @@ static int botic_hw_params(struct snd_pc } /* set the codec system clock */ - ret = snd_soc_dai_set_sysclk(codec_dai, 0, sysclk, SND_SOC_CLOCK_IN); + ret = snd_soc_dai_set_sysclk(codec_dai, 0, sysclk, clk_master ? SND_SOC_CLOCK_OUT : SND_SOC_CLOCK_IN); if ((ret < 0) && (ret != -ENOTSUPP)) return ret; /* use the external clock */ - ret = snd_soc_dai_set_sysclk(cpu_dai, 0, sysclk, SND_SOC_CLOCK_IN); + ret = snd_soc_dai_set_sysclk(cpu_dai, 0, sysclk, clk_master ? SND_SOC_CLOCK_OUT : SND_SOC_CLOCK_IN); if (ret < 0) { printk(KERN_WARNING "botic-card: unable to set clock to CPU; ret=%d", ret); return ret; @@ -311,6 +313,9 @@ static struct platform_driver asoc_botic module_platform_driver(asoc_botic_card_driver); +module_param(clk_master, int, 0644); +MODULE_PARM_DESC(clk_master, "Choose between clock master or slave"); + module_param(blr_ratio, int, 0644); MODULE_PARM_DESC(blr_ratio, "force BCLK/LRCLK ratio"); Index: git/dts/src/arm/BOTIC-00A0.dts =================================================================== --- git.orig/dts/src/arm/BOTIC-00A0.dts +++ git/dts/src/arm/BOTIC-00A0.dts @@ -78,18 +78,18 @@ mcasp0_custom_pins: mcasp0_custom_pins { pinctrl-single,pins = < /* bitclock */ - AM33XX_IOPAD(0x990, PIN_OUTPUT | MUX_MODE0) /* mcasp0_aclkx.mcasp0_aclkx */ + AM33XX_IOPAD(0x990, PIN_OUTPUT | PIN_INPUT | MUX_MODE0) /* mcasp0_aclkx.mcasp0_aclkx */ /* wordclock */ - AM33XX_IOPAD(0x994, PIN_OUTPUT | MUX_MODE0) /* mcasp0_fsx.mcasp0_fsx */ + AM33XX_IOPAD(0x994, PIN_OUTPUT | PIN_INPUT | MUX_MODE0) /* mcasp0_fsx.mcasp0_fsx */ /* data pins */ - AM33XX_IOPAD(0x998, PIN_OUTPUT | MUX_MODE0) /* mcasp0_axr0.mcasp0_axr0 */ - AM33XX_IOPAD(0x9a8, PIN_OUTPUT | MUX_MODE0) /* mcasp0_axr1 */ + AM33XX_IOPAD(0x998, PIN_OUTPUT | PIN_INPUT | MUX_MODE0) /* mcasp0_axr0.mcasp0_axr0 */ + AM33XX_IOPAD(0x9a8, PIN_OUTPUT | PIN_INPUT | MUX_MODE0) /* mcasp0_axr1 */ /* disable eCAP0_in_PWM0_out to allow usage of mcasp0_axr2 on P9_42 */ AM33XX_IOPAD(0x964, PIN_INPUT | MUX_MODE7) /* ecap0_in_pwm0_out.gpio0_7 */ - AM33XX_IOPAD(0x9a0, PIN_OUTPUT | MUX_MODE2) /* mcasp0_aclkr.mcasp0_axr2 */ - AM33XX_IOPAD(0x9a4, PIN_OUTPUT | MUX_MODE2) /* mcasp0_fsr.mcasp0_axr3 */ + AM33XX_IOPAD(0x9a0, PIN_OUTPUT | PIN_INPUT | MUX_MODE2) /* mcasp0_aclkr.mcasp0_axr2 */ + AM33XX_IOPAD(0x9a4, PIN_OUTPUT | PIN_INPUT | MUX_MODE2) /* mcasp0_fsr.mcasp0_axr3 */ /* master clock */ - AM33XX_IOPAD(0x9ac, PIN_INPUT | MUX_MODE0) /* MCASP0_AHCLKX -> MCASP0_AHCLKX (I2S_MCLK_OUT)- in */ + AM33XX_IOPAD(0x9ac, PIN_OUTPUT | PIN_INPUT | MUX_MODE0) /* MCASP0_AHCLKX -> MCASP0_AHCLKX (I2S_MCLK_OUT)- in */ >; }; Again, any thoughts you might have would be helpful. I'm a bit in the dark at the moment fully understanding how all these clocking settings are related. |
#3144 | |
If only use the BBB as streamers. Your images are very fast on/off <3s, and easily for the change other protocol in 1s direct on web browser, easy for new user linux system. I very like it. |
#3145 | |
#3146 |
Dear more experiences colleagues. I would like to ask you about help. For one project I need 4 channels DSD only NAA for HQPlayer. I bought BBB rev. C. It looks promise, BBB has external oscillators input on P9/25 and clock selection output on P9/24. Also has 4 usable serializers:
P9/27 mcasp0_axr3 (data3) = DSD4, P9/30 mcasp0_axr0 (data0) = DSD1, P9/41 mcasp0_axr1 (data1) = DSD2, P9/42 or 28 mcasp0_axr2 (data2) = DSD3, P9/31 DSD clock. I do not need DSD ON, LRCLK, BCLK…, but MUTE signal can be useful, but I don’t know, where can be remapped from commonly used P9/27. Can you recommended me which present system and driver can fit these requirements? And can you help me with some important steps, how can go through. I am hardware guy and not familiar with Linux, Botic … Thanks a lot |
#3147 |
exactly, that`s a good question.
Can the Mute pin applied when those 4 pins are used for Data? From Miero`s web site: -------- Mute pin -------- Notice: This parameter is available in botic7 Emulation of mute pin on some of 1-4 data pins: - kernel option snd_soc_davinci_mcasp.mute_pin - file /sys/module/snd_soc_davinci_mcasp/parameters/mute_pin which can be updated while system is running, but change will be applied on the next start of playback Supported values for mute_pin: -1 ... mute pin functionality is disabled or these additive numbers: + 1 ... signal mute on pin 0 + 2 ... signal mute on pin 1 + 4 ... signal mute on pin 2 + 8 ... signal mute on pin 3 + 16777216 ... invert the mute signal It seems the Mute Pin is just another Data signal, so with a Mute pin enabled the maximum PCM channels are 6 and the maximum DSD channels are 3? Any option to use different pins, or is this the result of having to give up 1 serializer for a Mute pin? Guys, anybody have an idea to get 4 DSD channels as well as 1 mute pin?
Fewer words pls! |
#3148 | |
Botic7 — Yandex.Disk at the Readme english file at the bottom it says: "When working via I2S, it is possible to use two types of mute signal 1. Signal generated by the driver - 27 pin P9 2. The signal generated by the system based on data from the players and the Alsa subsystem - 28 pin P9. Setting in the script /opt/mutedsc2.sh The firmware has standard user settings via the web interface Nymeria Shell access via SSH - root / root" You could try that and see if it works. Marco
Fewer words pls! |
#3149 |
I am afraid that P9/27 and P9/28 are booth serializers outputs and BBB has only 4 serializers. MUTE signal looks similar as DSD ON signal. For DSD only DAC don’t need DSD ON signal, so it can be useful replace it by MUTE. Or the best I think will be on P9/26 have something like NOR(DSD On) OR MUTE signal. Or use any another pin then P9/24, 25, 27, 31, 30, 41, 42 (28). Any idea?
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Open baffle with fullrange driver and bass support | Godzilla | Full Range | 5 | 22nd July 2011 02:32 PM |
Low end support for single driver monitors | strider75 | Multi-Way | 97 | 30th September 2009 04:02 PM |
ASIO support (driver) for Labview | Aoxomox | Digital Line Level | 0 | 3rd May 2009 06:29 PM |
Linux/BruteFIR support coming in LspCAD | tcpip | Multi-Way | 18 | 18th October 2005 04:08 AM |
linux | badgers | Introductions | 3 | 3rd April 2005 04:27 PM |
New To Site? | Need Help? |
