Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 18th March 2020, 06:20 AM   #3091
Oystein is offline Oystein  Netherlands
My manual is based on BeagleBone Black (wired LAN).
I have no experience with BB Green Wireless and did not develop Botic so I don’t know how to solve your wireless issue with Botic.
Can’t help you with that.
Last notes in my manual:
As I am not a Linux specialist (merely put all fragments of information together from the internet) I hope this manual is useful for many novice Linux / Botic users.
Old 18th March 2020, 09:20 AM   #3092
Originally Posted by chientechnical View Post
Only when apply "dtb=am335x-boneblack-botic.dtb" and reboot. All SSH connect to my BBGW missing.
Are you sure you als edited the line further down the uEnv.txt:
put # in front of “enable_uboot_cape_universal=1”
If you not disable this line by # it can happen (mostly at Debian 8) that the BB will not reboot.
You can also check visually on BB if the LED's are flashing or not.
If “enable_uboot_cape_universal=1” is causing trouble I had it that 2 LED's are on constant but no flashing.
Old 19th March 2020, 01:22 AM   #3093
chientechnical is offline chientechnical  Viet Nam
I can't the find enable_uboot_cape_universal = 1 before because I don't pulldown.
I'm successfully folow your guide now.
Botic and MPD/MPC running on 192.168.1.2 Texas Instrucment in my LAN.
MC & Nano are good. I see easy for the use, same as Windows OS
Old 19th March 2020, 02:07 AM   #3094
I'm using HQPlayer Desktop. I want the install NAA into BBGW.
Install will sane as below, right?
wget https://www.signalyst.eu/bins/naa/li...0-45_armhf.deb
sudo dpkg -i networkaudiod_4.1.0-45_armhf.deb
Old 19th March 2020, 01:46 PM   #3095
Exploring the possibilities of MPD I also included some http mp3 radio streams (.m3u) in /var/lib/mpd/playlists
The problem I have with that is the stream stops by itself after some time without obvious reason.
Maybe this is not Botic related but if somebody has experienced this too please let me know.
For testing I have 3 micro SD-cards with Debian 8, 9 and 10 and all the same issue.
Depending on Debian version MPD is 0.19 to 0.21.
The only common software is Botic 4.8.13
What I discovered is that at some point the Ethernet stream stops and the audio stops after approx 10 sec as the buffer empties itself.
This can happen after 10 minutes but also after a few hours.
Per day I will have to restart the stream a couple of times again.
I have tested with continues pinging external (internet) servers including the radio stream without showing any interrupts. Also pinging the BBB (10.0.0.50) local it stays live.
When I pull the modem cable the audio stops also after 10 seconds but starts by itself when replug the cable again.
When the stream stops by itself it never restarts automaticly and always have to re-start the stream again so reconfirming to play the stream. Pressing pause/play in the iOs app does not help.
With playing albums from my NAS no problem but don't have tracks lasting multiple hours ...
It never happened playing a complete album.
Here we can see the interruption of Rx data and pinging BBB from a local PC without any interrups:
Old 20th March 2020, 06:23 AM   #3096
Sorry! because I got a little confused.
I have tried it many times. Wifi onboard only problem when the me changed "#dtb=" into "dtb=am335x-boneblack-botic.dtb".
If I restore "dtb=am335x-boneblack-botic.dtb" into "#dtb=" as first and reboot my BBGW. So wifi onboard are normal performance.
I tried on Debian 8.7 & 9.5 & 10.0 & 10.3 problem same too.
Should, I mean can "am335x-boneblack-botic.dtb" does't support the wifi onboard default, right ?
Can anyone help me fix this problem? Tks so much
I using USB Wireless TL-WN722N v1.2 for connect to my LAN and Internet.
Old 24th March 2020, 12:56 PM   #3097
I installed HQPlayer networkaudiod_4.1.1-46_armhf.deb into BBGW runing Buster 10.3 Console 1GB.
HQPlayer Desktop playing nomal without problem.
I want the change parameter of Botic7. After edit to new parameter, then Ctl+O for "Save", and read again for sure. I see the parameter are changed to new parameter.
But, when I reboot BBGW - the parameter this auto return to default parameter first.
What is the problem of my and what to do to handle it. Thank you everyone
Support for Botic Linux driverHide this!Advertise here!
Open baffle with fullrange driver and bass support Godzilla Full Range 5 22nd July 2011 01:32 PM
Low end support for single driver monitors strider75 Multi-Way 97 30th September 2009 03:02 PM
ASIO support (driver) for Labview Aoxomox Digital Line Level 0 3rd May 2009 05:29 PM
Linux/BruteFIR support coming in LspCAD tcpip Multi-Way 18 18th October 2005 03:08 AM
linux badgers Introductions 3 3rd April 2005 03:27 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
