Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 6th December 2019, 08:04 AM   #2991
bern is offline bern  Poland
Originally Posted by coroner21 View Post
....If you want to have this functionality on more recent kernels, you can have a look and port this patch yourself: linux-dev/0013-pm-shutdown-on-power-button-press-or-power-loss.patch at botic7-v48 * miero/linux-dev * GitHub
Unfortunately I do not have sufficient skills. I'm no programmer or coder.
With regards to the module compilation: Maybe try with the default buster kernel. If this leads to the same problems, then probably the outdated code of the lirc-bbb module is to blame. If it works then we need to further investigate how the kernel headers are built for the boticized kernel.
I installed the newest image 'BBB-blank-debian-10.2-console-armhf-2019-12-02-1gb.img' which I could found in Index of /rootfs/bb.org/testing/2019-12-02/buster-console
The kernel is:
Code:
Linux beaglebone 4.19.79-ti-r30 #1buster SMP PREEMPT Mon Nov 4 20:38:01 UTC 2019 armv7l GNU/Linux
The compiling of 'lirc-bbb' stuck on:
Code:
debian@beaglebone:/mnt/SD/lirc-bbb$ sudo make prepare
make -C /lib/modules/`uname -r`/build scripts
make[1]: Entering directory '/usr/src/linux-headers-4.19.79-ti-r30'
  CC      scripts/mod/empty.o
  MKELF   scripts/mod/elfconfig.h
  HOSTCC  scripts/mod/modpost.o
  CC      scripts/mod/devicetable-offsets.s
  HOSTCC  scripts/mod/file2alias.o
  HOSTCC  scripts/mod/sumversion.o
  HOSTLD  scripts/mod/modpost
  HOSTCC  scripts/selinux/genheaders/genheaders
scripts/selinux/genheaders/genheaders.c:18:10: fatal error: classmap.h: No such file or directory
 #include "classmap.h"
compilation terminated.
make[4]: *** [scripts/Makefile.host:90: scripts/selinux/genheaders/genheaders] Error 1
make[3]: *** [scripts/Makefile.build:544: scripts/selinux/genheaders] Error 2
make[2]: *** [scripts/Makefile.build:544: scripts/selinux] Error 2
make[1]: *** [Makefile:1061: scripts] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-4.19.79-ti-r30'
make: *** [Makefile:35: scripts] Error 2
Old 6th December 2019, 08:51 AM   #2992
cu6apum is offline cu6apum  Russian Federation
Gentlemen!!!
How do i config alsa so it sees the Botic device as multichannel?! I have MMMM in serconfig but aplay sees only two.
/etc/asound.conf is pretty much default, but the board does see a USB multichannel DAC as really multichannel if plugged in.
Thank you!
Support for Botic Linux driverHide this!Advertise here!
Open baffle with fullrange driver and bass support Godzilla Full Range 5 22nd July 2011 02:32 PM
Low end support for single driver monitors strider75 Multi-Way 97 30th September 2009 04:02 PM
ASIO support (driver) for Labview Aoxomox Digital Line Level 0 3rd May 2009 06:29 PM
Linux/BruteFIR support coming in LspCAD tcpip Multi-Way 18 18th October 2005 04:08 AM
linux badgers Introductions 3 3rd April 2005 04:27 PM
Copyright ©1999-2019 diyAudio
