Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 1st December 2019, 06:37 PM   #2981
bern is offline bern  Poland
Originally Posted by amigo1 View Post
1. What do you mean under lack of satelite mode?
2. How about using M.A.L.P. or MPDROID?
3. Somе MPD versions sound not good, isn't it?
1. User’s Manual — Music Player Daemon 0.22 documentation
2. AFIK M.A.L.P is a MPD controller under development; MPDROID isn't.
3. I don't know. I prefer the newest version (less bugs, more new features)
Old 1st December 2019, 08:40 PM   #2982
coroner21 is offline coroner21
Support for Botic Linux driver
Originally Posted by bern View Post
What to do to set 'serconfig' and 'dai_format'?
Hi bern,
Setting dai_format or serconfig is not supported since I dropped the related code (only playback of both I2S as well as DSD is supported, no SPDIF) with standard dai format setting as appropriate for a Cronus or similar configuration.
If you have such a standard configuration this should work regardless of the dai_format / serconfig parameters.
Christian
Old 1st December 2019, 08:51 PM   #2983
Second issue with the build kernel.
I'm trying to build lirc-bbb module. I installed generated headers 'linux-headers-4.19.79+_4.19.79+-1_armhf.deb' but stuck at 'fatal error: classmap.h: No such file or directory'. See details.
Code:
debian@beaglebone:/opt/lirc-bbb$ sudo make prepare
make -C /lib/modules/`uname -r`/build scripts
make[1]: Entering directory '/usr/src/linux-headers-4.19.79+'
  HOSTCC  scripts/selinux/genheaders/genheaders
scripts/selinux/genheaders/genheaders.c:18:10: fatal error: classmap.h: No such file or directory
 #include "classmap.h"
compilation terminated.
make[4]: *** [scripts/Makefile.host:90: scripts/selinux/genheaders/genheaders] Error 1
make[3]: *** [scripts/Makefile.build:544: scripts/selinux/genheaders] Error 2
make[2]: *** [scripts/Makefile.build:544: scripts/selinux] Error 2
make[1]: *** [Makefile:1061: scripts] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-4.19.79+'
make: *** [Makefile:35: scripts] Error 2
Should I install something?
Sorry, cannot be of much assistance here... Are the headers indeed installed in '/usr/src/linux-headers-4.19.79+'? Could it be that lirc_bbb is not compatible with the 4.19 kernel for some reason? If you install the headers of the standard buster kernel, does it work?
Old 1st December 2019, 10:14 PM   #2984
Originally Posted by coroner21 View Post
Hi bern,
Christian
Thanks for replay.
That's a pity since some users (including me) use Cronus and Right Justified Data Format 'dai_format=16386' (instead of default 16385). Could you consider to restore this parameter as variable in one of the next releases?
Code:
debian@beaglebone:/usr/src/linux-headers-4.19.79+$ ls
Documentation  Makefile        arch   certs   drivers   fs       init  kernel  mm   samples  security  tools  virt
Kconfig        Module.symvers  block  crypto  firmware  include  ipc   lib     net  scripts  sound     usr
I don't know. I tried to build GitHub - miero/lirc-bbb: LIRC driver for BeagleBone Black module several times with previous kernels add it worked.
I have to check. I'm sure it worked with 'Linux beaglebone 4.8.13-botic7-rc3 #1 PREEMPT Sat Dec 10 01:35:51 CET 2016 armv7l GNU/Linux'
Old 3rd December 2019, 09:52 AM   #2985
Thanks for replay.
I just updated the debian-buster branch and this parameter is again enabled. Please try whether right justified works fine for you now.
Old 3rd December 2019, 10:15 AM   #2986
Can you try to directly call
Code:
make build
and skip the prepare step?
Old 3rd December 2019, 11:04 AM   #2987
Thank you!
I'm just checking out BBB debian kernel and going to build new one but this time I try to compile kernel directly on BBB machine (will take few hours). Last time I cross compiled BBB kernel on my home X64 Ubuntu server 19.10 machine.
Code:
make build
I will try when I have a new kernel. Let's keep our fingers crossed for successful kernel and module build
Old 4th December 2019, 10:51 AM   #2988
It took 15h to bulid BBB kernal on BBB machine.
After installing new kernel dai_format paramater (in my case Right Justified data format) works properly.
One strange think I encounter is lack of automatic shutdown after plug out the mains when using battery attached to Hermes (about battery see the end of the first post of Hermes thread). Before installing new kernel when I plug out the mains Debian automatically switch off in few seconds . It currently doesn't work. System still running discharging batterry. How could I fix this?
Code:
make build
It doesn't help much. Still lack of some files in headers directory:
Code:
  HOSTCC  scripts/basic/fixdep
scripts/basic/fixdep.c:97:10: fatal error: sys/types.h: No such file or directory
 #include <sys/types.h>
make[3]: *** [scripts/Makefile.host:90: scripts/basic/fixdep] Error 1
make[2]: *** [Makefile:467: scripts_basic] Error 2
make[1]: *** [Makefile:633: include/config/auto.conf.cmd] Error 2
debian@beaglebone:/opt/lirc-bbb$ sudo make build
make -C /lib/modules/`uname -r`/build M=$PWD
  CC [M]  /opt/lirc-bbb/lirc_bbb.o
/opt/lirc-bbb/lirc_bbb.c:31:10: fatal error: media/lirc.h: No such file or directory
 #include <media/lirc.h>
make[2]: *** [scripts/Makefile.build:310: /opt/lirc-bbb/lirc_bbb.o] Error 1
make[1]: *** [Makefile:1519: _module_/opt/lirc-bbb] Error 2
make: *** [Makefile:12: build] Error 2
Old 4th December 2019, 08:46 PM   #2989
ppy is offline ppy  Russian Federation
ppy's Avatar
Functionality extension in micro audiorender (beta):
  1. New audio renders of the LMS and AirPlay protocols have been added.
  2. Added support for wpa WFi.
Linux kernel remains the same - 4.9.146-Botic7-rt
http://puredsd.ru/buildroot/sd_botic7_V2.img.gz
ssh root/root
Old 4th December 2019, 09:57 PM   #2990
I abandoned the code for powering down on battery automatically. For my BBBW use case I found that simply hard power down (without taking care of proper shutdown) does not cause any issues so I do not have any battery and also I often do not shut down properly before removing power.
If you want to have this functionality on more recent kernels, you can have a look and port this patch yourself: linux-dev/0013-pm-shutdown-on-power-button-press-or-power-loss.patch at botic7-v48 * miero/linux-dev * GitHub
With regards to the module compilation: Maybe try with the default buster kernel. If this leads to the same problems, then probably the outdated code of the lirc-bbb module is to blame. If it works then we need to further investigate how the kernel headers are built for the boticized kernel.
Support for Botic Linux driverHide this!Advertise here!
Open baffle with fullrange driver and bass support Godzilla Full Range 5 22nd July 2011 02:32 PM
Low end support for single driver monitors strider75 Multi-Way 97 30th September 2009 04:02 PM
ASIO support (driver) for Labview Aoxomox Digital Line Level 0 3rd May 2009 06:29 PM
Linux/BruteFIR support coming in LspCAD tcpip Multi-Way 18 18th October 2005 04:08 AM
linux badgers Introductions 3 3rd April 2005 04:27 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
