Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 25th October 2019, 06:18 AM   #2951
Luca72c is offline Luca72c
Originally Posted by twluke View Post
Though this is not a topic for this thread:
5 months ago, a firmware bug for B3SEpro had been pointed out and Russ rewrote Buffalo.c and README.md for correction but the codes for SyncMode firmware were left as they were without correction. I'm not sure if this is related to your problem but anyway the firmware is experimental and if the problem continues, I'll abandon such one and will consider a Plan B like controlling the DAC by I2C which enables noise-free playing of DSD512 on HQP for now for me.
Thank you, i'm aware of this bug, but it's not my case...
Old 25th October 2019, 08:48 AM   #2952
coroner21 is offline coroner21
Support for Botic Linux driver
Originally Posted by pixelpusher View Post
Coroner21,
Thanks for providing this. I am not knowledgeable with Linux but trying to learn. The hash you posted contains a space that is not in the file. Would that indicate a problem?
Thanks again
Pixelpusher, no problem here. Definitely no white space is expected in an SHA256 hash. I think this is probably due to some automatic formatting being applied by the forum software if the CODE tags are not being used.
If you see the correct string but not including the space when you generate the checksum locally everything should be fine.
Old 25th October 2019, 08:51 AM   #2953
BTW, is it possible to get header files for this particular kernel? because I have a few modules to be updated for working.
I have added the header deb-package as well to the shared folder.
If I have some time later today I will also provide some more instructions so that people can easily build their own kernel based on the beaglebone.org repository. I have already created a debian-buster branch for this purpose in my github repository.
Old 25th October 2019, 09:27 AM   #2954
twluke is offline twluke  Japan
Thank you for your quick work. I really appreciated it. BTW, the revised image file worked well for playing DSD512 as expected.
That would be quite helpful. Thank you.
Old 8th November 2019, 06:59 PM   #2955
amigo1 is offline amigo1
amigo1's Avatar
Default Debian 10.1 for beaglebone black C
Debian 10.1 for beaglebone black C is released:
Debian Buster Console
https://rcn-ee.com/rootfs/bb.org/tes...-21-1gb.img.xz
Debian Buster IOT
https://rcn-ee.com/rootfs/bb.org/tes...-21-4gb.img.xz
Old 10th November 2019, 09:32 PM   #2956
Abra is offline Abra  Hungary
I'm confused:
debian@beaglebone:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 8.3 (jessie)
Release: 8.3
Codename: jessie
Old 11th November 2019, 06:09 PM   #2957
amigo1's Avatar
Originally Posted by Abra View Post
I'm confused:
Release: 8.3
Codename: jessie
Is it misrepresentation of RCN?
Old Yesterday, 07:58 AM   #2958
I started to study Linux commands just a few days ago, to add a chance coroner21' image.
What I know, installing debian packages in a standard mode seems impossible:
debian@beaglebone:~$ sudo apt-get install lsb-core
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package lsb-core
debian@beaglebone:~$ sudo apt-get install mpd
E: Unable to locate package mpd
A possible answer for this phenomen Jessie is not compatible with Debian 10 packages.
I also tried other installation commands (wget used for manual download, apt & dpkg used to install), but without success.
There are unresolvable dependency errors when installing Buster packages.
Experts may tell what I was failed.
Support for Botic Linux driverHide this!Advertise here!
Open baffle with fullrange driver and bass support Godzilla Full Range 5 22nd July 2011 02:32 PM
Low end support for single driver monitors strider75 Multi-Way 97 30th September 2009 04:02 PM
ASIO support (driver) for Labview Aoxomox Digital Line Level 0 3rd May 2009 06:29 PM
Linux/BruteFIR support coming in LspCAD tcpip Multi-Way 18 18th October 2005 04:08 AM
linux badgers Introductions 3 3rd April 2005 04:27 PM
Copyright ©1999-2019 diyAudio
