Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 19th October 2019, 09:16 PM   #2911
coroner21 is offline coroner21
Support for Botic Linux driver
Not sure whether a lot of power or RAM is really needed. On my BBBW I run MPD for music playback as well as a pulseaudio server and shairport-sync in order to stream from other devices. Occasionally also rompr is used as web frontend to the MPD which is probably most resource hungry.
MPD gets its music library using the proxy DB plugin from a NAS which shares roughly 700GB of music files using NFS protocol.
Still, with this setup I have more than 50% of free memory and while playing audio the cpu is 70% idle (CPU is also most of the times clocked down to 300-600MHz only). So it seems like this machine has clearly more than enough of power...
Probably Volumio just comes with a lot of unnecessary bloat hogging the resources.
Old 19th October 2019, 10:36 PM   #2912
amigo1 is offline amigo1
amigo1's Avatar
Unfortunately we haven't OS for BBB as good as Volumio.
Old 20th October 2019, 08:58 PM   #2913
amigo1's Avatar
Default Arch or Debian for Beaglebone Black?
Please explaine, how you use RompЯ via smartphone? Have You installed web frontend to MPD Arch Package rompr 1.26-1 AUR (en) - rompr ?
RompЯ | A beautiful, feature-rich music player.
Old 21st October 2019, 12:07 PM   #2914
No, I did not use the AUR package but instead simply followed the installation guide on the rompr site (using nginx). However I remember that I had to read through a lot of the nginx archlinux wiki page and made some changes to the configuration that were necessary to have it running in the end.
To use it on the smartphone, I simply open Nymeria where IP is the BBBW address. I have no other http site enabled on the BBBW so the standard IP directly opens rompr for me. Works without issues.
Old 21st October 2019, 12:09 PM   #2915
What unique features of Volumio are there that you cannot make work on some generic linux flavor?
Old 21st October 2019, 06:39 PM   #2916
amigo1's Avatar
Default RompЯ for beaglebone black
Would you so kind as to write a short guide how to install RompЯ on arch linux?
Old 21st October 2019, 06:41 PM   #2917
amigo1's Avatar
It has user-friendly interface and brilliant sound quality
Old 21st October 2019, 07:01 PM   #2918
Abra is offline Abra  Hungary
Yes, and easy to install for non-unix guys too. But unfortunately it's dead.
Terminal commands, or a bit better?
Old 21st October 2019, 07:24 PM   #2919
It has ... brilliant sound quality
What makes it so exceptional?
Old 21st October 2019, 08:39 PM   #2920
amigo1's Avatar
Debian based linux OS.
Support for Botic Linux driverHide this!Advertise here!
Open baffle with fullrange driver and bass support Godzilla Full Range 5 22nd July 2011 02:32 PM
Low end support for single driver monitors strider75 Multi-Way 97 30th September 2009 04:02 PM
ASIO support (driver) for Labview Aoxomox Digital Line Level 0 3rd May 2009 06:29 PM
Linux/BruteFIR support coming in LspCAD tcpip Multi-Way 18 18th October 2005 04:08 AM
linux badgers Introductions 3 3rd April 2005 04:27 PM
Copyright ©1999-2019 diyAudio
