Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 30th August 2019, 07:58 PM   #2881
amigo1 is offline amigo1
amigo1's Avatar
Default Debian10 Buster for Beaglebone black
Old 30th August 2019, 10:10 PM   #2882
pixelpusher is offline pixelpusher  United States
Amigo please go away.
Old 31st August 2019, 06:11 PM   #2883
amigo1's Avatar
I know that Americans are generally ruder than people from other countries ! Isn't it?
Old 12th September 2019, 09:58 AM   #2884
mr_whocares is offline mr_whocares  Germany
Default Installation of Botic kernel into volumio 1.5BBB
dear miero, dear alle!
any reply to my post
Support for Botic Linux driver
any suggestions how to install the botic kernel into volumio 1.5BBB? unfortunately the botic scripts on the miero website don't work anymore and need to be updated :-(
thanks and regards
Old 12th September 2019, 06:00 PM   #2885
thanks and regards
since wheezy and jessy are not supported anymore and moved to "archive", i think miero has to change some of his files/scripts.
updating "sources.list" according to the new debian "archive" servers seems not to be enough :-(
@ miero: please advice and help!
many thanks
Old 12th September 2019, 06:30 PM   #2886
many thanks
update:
changing the sources.list to archive.debian.org did the job! now it seems everything to work fine! :-)
Old 12th September 2019, 07:44 PM   #2887
amigo1's Avatar
Maybe a link for RP will help?:
volumio mirror repo * volumio/Build@b04fe63 * GitHub
deb Index of /debian jessie main ui
deb-src Index of /debian jessie main ui
deb http://archive.volumio.org/debian/ jessie main ui
deb-src http://archive.volumio.org/debian/ jessie main ui
The jessie-backports suite was archived on archive.debian.org, so you can use:
deb http://archive.debian.org/debian/ jessie-backports main contrib non-free
deb-src http://archive.debian.org/debian/ jessie-backports main contrib non-free
Old 12th September 2019, 08:20 PM   #2888
amigo1's Avatar
Using Debian Long Term Support (LTS)
LTS/Using - Debian Wiki
Important: Jessie-LTS only supports i386, amd64, armel and armhf. Users of other architectures are encouraged to upgrade to Debian 9 ("Stretch").
The current LTS version is Debian 8 "Jessie" and will be supported from 2018-06-17 to 2020-06-30. To receive security updates, your /etc/apt/sources.list should look like this one:
deb Index of /debian jessie main contrib non-free
deb-src Index of /debian jessie main contrib non-free
deb Debian -- Security Information jessie/updates main contrib non-free
deb-src Debian -- Security Information jessie/updates main contrib non-free
Old 12th September 2019, 09:17 PM   #2889
thanks amigo1, i changed the links in the sources.list to archive.debian.org and it works well.
Support for Botic Linux driverHide this!Advertise here!
Open baffle with fullrange driver and bass support Godzilla Full Range 5 22nd July 2011 01:32 PM
Low end support for single driver monitors strider75 Multi-Way 97 30th September 2009 03:02 PM
ASIO support (driver) for Labview Aoxomox Digital Line Level 0 3rd May 2009 05:29 PM
Linux/BruteFIR support coming in LspCAD tcpip Multi-Way 18 18th October 2005 03:08 AM
linux badgers Introductions 3 3rd April 2005 03:27 PM
Copyright ©1999-2019 diyAudio
