Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 23rd August 2019, 01:21 PM   #2871
wealas is offline wealas
Not the kbuild package, the linux-kbuild package: Debian -- Details of package linux-kbuild-4.19 in buster - obviously this version won't work.
Old 24th August 2019, 10:19 AM   #2872
amigo1 is offline amigo1
amigo1's Avatar
Default MPD 0.20.23 оr 0.21.13 to Beaglebone Black, Debian 10
Originally Posted by wealas View Post
MPD
Please explain, which MPD 0.20.23 оr 0.21.13 you prefer install to Beaglebone Black?
Old 25th August 2019, 05:55 PM   #2873
Neither, I was only using mpd for testing, I moved away from the BBB altogether.
Old 26th August 2019, 06:56 AM   #2874
amigo1's Avatar
Default Debian 10 for BBB
Why you have moved away from the BBB?
Old 27th August 2019, 09:03 AM   #2875
Oystein is offline Oystein  Netherlands
Originally Posted by twluke View Post
Thank you again for your support here (August, 9th) to get your image working.
I had multiple issues and after some testing I relaised what went wrong.
First of all my drive mount (mount -a) was not maintained after reboot.
I managed to fix this.
Due to my very limited Linux knowledge it took me some time to realise that the command "mpc play" only gives a result if MPD is playing a song which I could nog manage in the beginning.
The only final persistent problem is that I have troubles getting MPD to work after reboot.
Many times I have to run the following commands again to get it running:
systemctl stop mpd.service
systemctl daemon-reload
systemctl start mpd.service
I already edited /lib/systemd/system/mpd.service (replaced $MPDCONF with /etc/mpd.conf)
Then I test MPD by "systemctl status mpd.service" to see if it gives no errors, then the system works as expected.
Are there some debugging commands I can try when I get errors at "systemctl status mpd.service" ?
Old 27th August 2019, 10:08 AM   #2876
twluke is offline twluke  Japan
Support for Botic Linux driver
If mount -a after each reboot is somewhat annoying, you can automatically launch this command using /etc/rc.local. As the recent debian system including my image does not originally support this function, you have to make it enable. The method is well written in this URL.
-snip-
Your approach is correct. The MPD does not automatically start after booting. If the original contents in the /root directory are mostly remaining, you can find "on", "off" and "stat" scripts there, which are executable. If you want to start MPD, just send ./on and then ./stat for checking status. Then you can start mpc play. If you want to stop MPD, just send ./off.
I don't know such commands but the bottom lines in systemctl status mpd.service will always give you such hints.
Old 27th August 2019, 10:52 AM   #2877
mr_whocares is offline mr_whocares  Germany
i had the same issue with running mpd. and the mdp database could not get updated properly as well. the solution was to re-install mpd. after that everything is working fine!
just do:
apt-get remove mpd
apt-get install mpd
my only issue is that the wlan connection is unstable and getting interrupted regularly . but this seems to be a known issue with debian in general.
thanks a lot again to twluke for the image!
Old 27th August 2019, 01:08 PM   #2878
bern is offline bern  Poland
Originally Posted by coroner21 View Post
Found the cause of the major problem with buffer underruns in case more serializers were enabled: Apparently a code change in mcasp caused unused serializers not to be explicitly de-activated anymore which does not really work for our purposes.
Reversing this and applying another minor patch based on miero's initial patch set for the botic driver I am now able to get also DSD working and sample rates up to 384khz.
The updated driver based on linux-4.19 should work with the following (only stereo playback tested on my side though):
  • Standard I2S playback (up to 384khz on 8 channels)
  • DSD playback (up to 4 channels tested only with DSD64 so far (I do not have any other DSD files))
  • I2C control of an ES9018 DAC using sabre32 codec (use the botic codec for generic I2S DAC)
Since I do not need or use it I did not care to maintain the code for the record / SPDIF configuration: This updated driver only works in I2S / DSD mode and the serconfig parameter is not parsed anymore. In addition, my clocks are 45158400 and 49152000 so this is how the driver is configured per default (the usual module parameters can be used to overwrite this).
I have created a github repository and instructions are provided there if anyone wants to try this: GitHub - coroner21/linux-am33xbot: Arch Linux ARM Kernel with botic patches
I installed Arch Linux on my BBB and would like to build patched Botic kernel.
After cloning the repository when I start with:
Code:
makepkg -A
I receive an error:
Code:
/bin/sh: arm-linux-gnueabihf-gcc: command not found
Do I really need recompiller on armv7l (BBB) machine?
It would be nice to have a new fresh image of Arch with Botic patched kernel.
Old 28th August 2019, 10:07 PM   #2879
amigo1's Avatar
Default New Volumio img for beaglebone black
Please specify, why your last Volumio img file for beaglebone black is so big?
Mayby it is time to re-release it ?
Old 29th August 2019, 10:11 AM   #2880
Default /source/boticize/01-addrepos.sh , /source/boticize/02-install.sh
hi miero,
i have been trying to re-install my volumio1.5BBB again. during the boticizing according to your old instructions, which always worked very fine for me in the past, i am getting now messages that many links can not be found anymore during executing the boticize scripts :-(
(please see the scripts
/source/boticize/03-enablepm.sh )
any chance to update the scripts or any suggestions please? thanks a lot for you support !
best regards
Support for Botic Linux driverHide this!Advertise here!
Open baffle with fullrange driver and bass support Godzilla Full Range 5 22nd July 2011 01:32 PM
Low end support for single driver monitors strider75 Multi-Way 97 30th September 2009 03:02 PM
ASIO support (driver) for Labview Aoxomox Digital Line Level 0 3rd May 2009 05:29 PM
Linux/BruteFIR support coming in LspCAD tcpip Multi-Way 18 18th October 2005 03:08 AM
linux badgers Introductions 3 3rd April 2005 03:27 PM
Copyright ©1999-2019 diyAudio
