Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 14th June 2019, 09:36 AM   #2791
ppy is offline ppy  Russian Federation
ppy's Avatar
Micro Linux - buildroot + kernel 4.9.146-Botic7-rt
http://puredsd.ru/botic7-image.gz or if the site is unavailable - MEGA
Contains:
  1. MPD 0.20.23 rt patch
  2. Aprenderer 2.02 (AlbumPlayer upnp renderer)
  3. Network Audio Adapter (HQPlayer Sygnalist)
  4. RoonBrige
Old 14th June 2019, 09:54 AM   #2792
Blitz is offline Blitz  Germany
Great stuff..will try...so far on my list:
- Micro Linux (just posted)
- Arch Botic
- LightMPD
- Build your own with Fred's instruction
- Same, but with DietPi
- TW_Luke's revised Kernel
I am not a Linux guy at all, but used MPDpuppy now for many years on an Alix1D board...so I am a believer in light-weight solutions, enabling ideally as well underclocking (not sure if the beaglebone has that option)
Old 14th June 2019, 01:44 PM   #2793
francolargo is offline francolargo  United States
Originally Posted by Blitz View Post
I would think that NOT attaching the Hermes/Cronus to the BBG and simply powering it over 5V from its microUSB-port should be safe, no ? Or can the hardware still be destroyed if the system has not been shutdown appropriately ?
I would think that getting MPD to work, have connection to the NAS etc all of that should be configurable without Hermes and Cronus attached, no ?
MPD will probably need Hermes/Cronus powered and attached. Damage to the BBG can occur if power is removed while there is voltage on the GPIO pins. If you always use the ‘shutdown’ command you should be OK.
Old 28th June 2019, 10:46 AM   #2794
ppy's Avatar
Next version mini Botic7 firmware
http://puredsd.ru/buildroot/sd_botic7.img.gz
  • Change: small changes webinterface
  • Fix: MPD can now play DSD256 and DSD512
The firmware was created primarily for PPY's ReClocker and new version DSC2.
But it can be used as a universal network transport for PCM/DSD and with other equipment. It is enough to do the configuration in the file /boot/uEnv.txt
SSH root/root
And buildroot for this firmware:
http://puredsd.ru/buildroot/buildroot_botic7.tar.bz2
Old 6th July 2019, 11:59 AM   #2795
coroner21 is offline coroner21
Update: GitHub - coroner21/linux-am33xbot: Arch Linux ARM Kernel with botic patches is now up to date with linux version 5.15. Note that for all three codec drivers (ES9018K2M, ES9018, Botic dummy-codec) I now enabled DSD_U32 again, which means that at least DSD256 is supported.
Background is that the MPD bug causing distortions in case of DSD_U32 playback was fixed in MPD version 0.21.11.
Old 8th July 2019, 08:17 AM   #2796
ppy's Avatar
There I have not yet fully understood whether MPD as well works here only as a renderer (so dumb client)
In my version of MPD, it works as a UPNP renderer.
MPD does not have the ability to connect directly to the music database. This is done intentionally.
but would love to be able to play Tidal as well...which so far I was not able to...
You can do this without any problems using the BubbleUPnP program.
Tidal -> BubbleUPnP -> UPNP renderer
or
Roon+Tidal -> Roon Bridge
Old 8th July 2019, 03:01 PM   #2797
amigo1 is offline amigo1
amigo1's Avatar
Thank you for the explanation!
As far as I understand the best way for my needs (playing m3u playlist files) I should use Debian BUSTER or ARCH LINUX with Botic Driver and necessary packages.
MPD ->UPNP renderer> BubbleUPnP
Old 8th July 2019, 08:59 PM   #2798
Funny moderation experience...not sure why stuff got deleted.
ppy, coming back how to make the mpd renderer function works...any server suggestion ? I guess this is how it works generally, no ? An UPnP Audio Media Renderer based on MPD
I am using BBb, chronus, hermes to drive B3, Soekris DAC...amd later maybe compare this with DSCv2...its great that you build an image that is so universally usable.
Old 9th July 2019, 07:09 AM   #2799
ppy's Avatar
I usually listen to Roon and HQPlayer.
I checked UPNP with Jriver. It is convenient, it is both a server and a controlpoint. But you can use any DLNA server. A good, free and functional server - MinimServer
You have correctly indicated the UPNP MPD operation scheme. An additional front-end is used - upmpdcli.
Old 9th July 2019, 11:23 AM   #2800
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Support for Botic Linux driver
Stuff got moved to a separate thread after several requests/complaints. Sorry for the confusion.
Non-Botic BBB Questions (amigo1 thread)
Support for Botic Linux driverHide this!Advertise here!
Open baffle with fullrange driver and bass support Godzilla Full Range 5 22nd July 2011 01:32 PM
Low end support for single driver monitors strider75 Multi-Way 97 30th September 2009 03:02 PM
ASIO support (driver) for Labview Aoxomox Digital Line Level 0 3rd May 2009 05:29 PM
Linux/BruteFIR support coming in LspCAD tcpip Multi-Way 18 18th October 2005 03:08 AM
linux badgers Introductions 3 3rd April 2005 03:27 PM
Copyright ©1999-2019 diyAudio
