Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 21st May 2019, 06:04 PM   #2771
D3nsityD3nt is offline D3nsityD3nt  Italy
Support for Botic Linux driver
On my botic 4.5 placed on eMMC I was experimenting with your examples of network directories to my PC.
My pc name on the net is DESKTOP-5LSFDSN, user name Living Room. No password.and condivided volder E://Music
This didn’t work
//192.168.1.167/Music /data cifs uid=mpd,file_mode=0777,dir_mode=0777,iochars et=utf8,rsize=130048,wsize=4096 0 0
I skipped password as there is none. Didn’t work naither.
//192.168.1.167/Music /data cifs username= DESKTOP-5LSFDSN ,uid=mpd,file_mode=0777,dir _mode=0777,iochars et=utf8,rsize=130048,wsize=4096 0 0
Should I write Password=none?
Or should I use Living Room (Living_Room) instead of DESKTOP-5LSFDSN?
Old 21st May 2019, 06:06 PM   #2772
Ok, thanks this makes thing clear. I thought that is necessary to work in the root directory. But using sudo in debian dir, I can do basicaly the same things as I understood.
Old 21st May 2019, 06:13 PM   #2773
twluke is offline twluke  Japan
This didnít work
I skipped password as there is none. Didnít work naither.
It is not PC name but your ID for PC. If not set, remove username and password. OKAY?
Old 21st May 2019, 06:31 PM   #2774
If not work, then insert username="Living Room",password=none or username only
Old 22nd May 2019, 06:10 AM   #2775
Default Apologies
-snip-
This didn’t work
Probably the lines above would be incomplete but I realized that my procedural order for cifs and mpd installation was not accurate. The point is that you can not edit /etc/fstab before MPD installation, because there is no mpd for uid. Trying mount -a without installation will always fail because of no user called mpd.
So please edit /etc/fstab after mpd installation. My sincere apologies to you for this inconvenience.
Old 22nd May 2019, 04:28 PM   #2776
Hello twluke. No need for apologies. If so then from my side rather as I was pretty intense.
That is good news. I have done some more homework yesterday and I have installed everything up to the point of mpd. Squeezelite works and I'm ready for mpd and connection to my pc server. I could not do anything with your copy of the botic as it is set to read only, and that was little over my strenght :-). Therefore I started from a scratch and it went smoothly good. This evening I will do a backup, and then if time stand by me, all the rest. I will also revisit my pc setup and firewall settings (Kaspersky).
I will report on how Im doing.
Now I'm looking into may stock of chockes and caps as I see that I need separate and very good power to the cronus.
Best regards
Kris
Old 22nd May 2019, 06:19 PM   #2777
Hi, many thanks for your comment.
-snip-
I know occasionally this happens. It is due to the primary UUID setting of /etc/fstab in the original image disk.
After booting from eMMC, insert the SD card to which the .img file was copied into the SD slot and do lsblk -f as root. The results will be shown like the example below:
Code:
root@arm:~# lsblk -f
NAME         FSTYPE LABEL  UUID                                 MOUNTPOINT
mmcblk0
└─mmcblk0p1  ext4   rootfs 4e974568-171a-423a-8145-0228a5685b42
mmcblk1
└─mmcblk1p1  ext4   rootfs 3c6b1707-1c88-448d-9e41-8d72540eec34 /
mmcblk1boot0
mmcblk1boot1
Remember the UUID of /dev/mmcblk0p1 and replace the UUID in the /etc/fstab of the copied SD card with it by editing. After that the read-only problem will be solved.
Best regards
Kris
That is a very good news. Now you appear to begin to walk on your own feet.
Old 22nd May 2019, 07:44 PM   #2778
Rather knees and elbows :-) But you have to start from somwhere. I need to get armed in some patience, cause as youv'e said, there is a long and bumpy road to go.
Thanks for info
Kris
Old 25th May 2019, 11:40 AM   #2779
coroner21 is offline coroner21
Please be informed everyone that the Arch Linux botic kernel repository GitHub - coroner21/linux-am33xbot: Arch Linux ARM Kernel with botic patches has been updated to linux version 5.1.3.
Old 27th May 2019, 11:36 AM   #2780
doremi is offline doremi
@coroner21: Would you mind uploading again the image you mentioned in #2621 (or a newer one)?
I messed up mpd on my installation.
Support for Botic Linux driverHide this!Advertise here!
Open baffle with fullrange driver and bass support Godzilla Full Range 5 22nd July 2011 01:32 PM
Low end support for single driver monitors strider75 Multi-Way 97 30th September 2009 03:02 PM
ASIO support (driver) for Labview Aoxomox Digital Line Level 0 3rd May 2009 05:29 PM
Linux/BruteFIR support coming in LspCAD tcpip Multi-Way 18 18th October 2005 03:08 AM
linux badgers Introductions 3 3rd April 2005 03:27 PM
Copyright ©1999-2019 diyAudio
