Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 21st May 2019, 04:26 PM   #2761
D3nsityD3nt is offline D3nsityD3nt  Italy
Support for Botic Linux driver
Originally Posted by twluke View Post
No backup? Then you have to repeat the procedures so far from the scratch.
Otherwise download my disk image from this link. It contains everything for botic and mpd but squeezelite. If you write proper entry into the /etc/fstab and the mouting directory by cifs, you'll be ready for MPD.
BTW, do not do what you are not understanding without confirmation.
Hello twluke.
On your disk, the password to root directory which should be botic does not work. Debian is ok.
Old 21st May 2019, 05:13 PM   #2762
twluke is offline twluke  Japan
Originally Posted by D3nsityD3nt View Post
Hello twluke.
There is no password for root. Do sudo or sudo -i. Otherwise create root password by yourself.
Old 21st May 2019, 05:31 PM   #2763
I'm constantly receivind Access denied to root
Old 21st May 2019, 05:33 PM   #2764
whatever I write or don't write.
Old 21st May 2019, 05:34 PM   #2765
Fore example:
sudo systemctl start mpd.service
Your debian password will be asked to enter.
Old 21st May 2019, 05:36 PM   #2766
sudo nano or sudo vi.
Old 21st May 2019, 05:39 PM   #2767
There is man command to help you. If stmbled, go to man page like: man sudo.
Old 21st May 2019, 05:46 PM   #2768
Yes, once I will log in then I will use sudo. But I cant login to root. Asks me for pass and nothing works. Nor botic no without pass. How can I login to root?
Old 21st May 2019, 05:53 PM   #2769
Becoming root is not recommended in the Linux env generally.That is why sudo is used. If still wanting to become root, do this.
sudo passwd root
Your debian pswd will be asked Enter it.
Then root pswd will be asked. Enter your preferred password. I wrote this before.
Old 21st May 2019, 05:54 PM   #2770
Then su root with root pswd will make you root. Because of many typos, I've edited many times. Recheck my posts so far.
Support for Botic Linux driverHide this!Advertise here!
Open baffle with fullrange driver and bass support Godzilla Full Range 5 22nd July 2011 01:32 PM
Low end support for single driver monitors strider75 Multi-Way 97 30th September 2009 03:02 PM
ASIO support (driver) for Labview Aoxomox Digital Line Level 0 3rd May 2009 05:29 PM
Linux/BruteFIR support coming in LspCAD tcpip Multi-Way 18 18th October 2005 03:08 AM
linux badgers Introductions 3 3rd April 2005 03:27 PM
Copyright ©1999-2019 diyAudio
