Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 8th March 2019, 09:37 AM   #2631
miero is offline miero  Czech Republic
cu6apum, yet it should be possible. you can use any other two available GPIO pins. the configuration is changed in the DTS file, so you need to recompile at least this file
BeagleBone Black with I2S, DSD and SPDIF interface (Linux driver)
http://bbb.ieero.com/
Old 9th March 2019, 01:05 PM   #2632
coroner21 is offline coroner21
Quick update: GitHub - coroner21/linux-am33xbot: Arch Linux ARM Kernel with botic patches was updated to linux kernel version 5.0.
Old 9th March 2019, 05:14 PM   #2633
cu6apum is offline cu6apum  Russian Federation
Great! Does power mgmt work? The 4.8.13 knows nothing about governors / sleep / mem mode...
Thanks, will try to figure out the way to pass this to kernel cmdline...
Old 9th March 2019, 07:29 PM   #2634
Regarding power mgt: what I could verify is cpufreq working fine. Sleep / standby I never tested, not sure if it is at all implemented for BBB.
For the GPIO pins: Kernel cmdline is not the right thing here. You will need to regenerate the device tree and specify there which pins are used for the switches.
Old 14th March 2019, 08:28 PM   #2635
Heathkit is offline Heathkit  United States
I am using BBB with Hermes/Cronus reclocker and I2S output (no USB) to a DDDAC. Is there a way to get info from BBB or Hermes/Cronus to drive simple LED's to indicate 44.1, 88.2, 176.4, 48, 96, or 192 sample rate of the file I am playing? As a bonus, but not necessary, bit depth indication of 16 or 24 would be nice too.
Sorry if this was covered, I tried searching this topic but found nothing.
Thanks!
Just because you can do-it-yourself, doesn't mean that you shouldn't...
Old 15th March 2019, 01:47 AM   #2636
francolargo is offline francolargo  United States
Yes, this can be done. I do something similar but with text output rather than LED output. ...though I don't care about bit depth.
Steps include:
A. Make an LED driver circuit if the LEDs you want to use draw too much current for direct drive from GPIO pins. [This is probably the case.] I use a simple 8 channel driver chip - ULN2803 or similar.
B. Learn how to initialize and control GPIO pins. I suggest doing this in Python, though bash works too.
C. Write a simple program to sense the parameters and indicate the results. You are talking about 6 rates and two bit depths, or 8 LEDs. Is that satisfactory? Another option is to use RGB LEDs and display color rather than lots of on-off locations. If I2C is an option, you have more display choices.
I have Python code working for options B and C, and am happy to share.
Old 15th March 2019, 02:46 AM   #2637
Thanks very much for your reply. I would appreciate the use of your Python code for the LED control.
Old 15th March 2019, 03:45 AM   #2638
No problem. Since this is not specifically related to the kernel, meet me over at:
Control of BBB-based audio appliances
Frank
Old 20th March 2019, 04:29 PM   #2639
janho12345 is offline janho12345  Germany
I know this might be annoying for some people but I think it’s still interesting and an add on to the compatibility of playback methods:
In this new thread, encoded surround audio is received optically and fed to BB by i2s. The BeagleBone encodes the audio and gives out multichannel i2s.
Surround decoder for encoded digital audio (AC3, DTS, AAC) with Beagle Bone Black
I it possible to integrate that on top of botic?
Old Yesterday, 01:45 AM   #2640
...clip...
Is it possible to integrate that on top of botic?
It could be done. If I remember correctly, Botic still won't accept SPDIF input. But you can get around that by using a SPDIF to USB converter and there are several that I know of that do a good job. Botic/ALSA can manage the multi-channel streams and output them on different I2S channels. For example, here is 'arecord -L' from my BBB:
Code:
sysdefault:CARD=miniStreamer
    miniStreamer, USB Audio
    Default Audio Device
front:CARD=miniStreamer,DEV=0
    Front speakers
surround21:CARD=miniStreamer,DEV=0
    2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=miniStreamer,DEV=0
    4.0 Surround output to Front and Rear speakers
surround41:CARD=miniStreamer,DEV=0
    4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=miniStreamer,DEV=0
    5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=miniStreamer,DEV=0
    5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=miniStreamer,DEV=0
    7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=miniStreamer,DEV=0
    IEC958 (S/PDIF) Digital Audio Output
dmix:CARD=miniStreamer,DEV=0
    Direct sample mixing device
dsnoop:CARD=miniStreamer,DEV=0
    Direct sample snooping device
hw:CARD=miniStreamer,DEV=0
    Direct hardware device without any conversions
plughw:CARD=miniStreamer,DEV=0
    Hardware device with all software conversions
root@beaglebone:/#
For this SPDIF->USB converter, the data source would be 'surround71:' from ALSA and the output would come from any of a few BBB program options for piping I2S out to Cronus. The I2S data could be 'as good as it gets', considering the signal source. However, the pipe programs may lock the sample rate rather than adapt if the stream changes frequency. You could adjust them manually. I believe that the snd_aloop module for ALSA can bypass the frequency restrictions of, for example 'aplay' or sox. I haven't needed to investigate that because all my SPDIF input is one frequency. Latency can be a deal-breaker for video sources. As a pipe and I2S renderer, the BBB can function well within the constraints of acceptable 'lip-synch'.
In my book, 7.1 surround is an interesting standard, is OK with video, but not meant for serious music reproduction because of the extreme phase and sampling issues.
Frank
Support for Botic Linux driverHide this!Advertise here!
Open baffle with fullrange driver and bass support Godzilla Full Range 5 22nd July 2011 01:32 PM
Low end support for single driver monitors strider75 Multi-Way 97 30th September 2009 03:02 PM
ASIO support (driver) for Labview Aoxomox Digital Line Level 0 3rd May 2009 05:29 PM
Linux/BruteFIR support coming in LspCAD tcpip Multi-Way 18 18th October 2005 03:08 AM
linux badgers Introductions 3 3rd April 2005 03:27 PM
Copyright ©1999-2019 diyAudio
