Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Thread Tools
Old 29th April 2018, 10:56 AM   #2461
yanpetr is offline yanpetr  Russian Federation
Originally Posted by mikelangeloz View Post
Of course, if there's any help needed just feel free to ask me!
mikelangeloz, Hi!
in a new assembly volumio, which recently collected and posted on the forum,
It does not work to mount a folder (SAMBA) via the web interface.
The size, its name is visible, but it DOES NOT be MOUNTED.
register in additional settings "vers = 1.0, 2.0" 0 does not help
Help solve this?
Old 29th April 2018, 11:57 AM   #2462
miero is offline miero  Czech Republic
it might be an issue of the old kernel. maybe it's a time for an upgrade (task for me)
BeagleBone Black with I2S, DSD and SPDIF interface (Linux driver)
http://bbb.ieero.com/
Old 29th April 2018, 12:28 PM   #2463
thanks,Miero!
Old 29th April 2018, 06:58 PM   #2464
cu6apum is offline cu6apum  Russian Federation
Bummer. Now i'm setting up DSD and see no way to mux bclk (in pcm mode) and second dsd channel?!
I have no extra wire from bbg, so what has to be done in order to get standard iis/dsd bus?
Thank you. Please help!
Old 11th May 2018, 06:25 PM   #2465
bern is offline bern  Poland
I use Debian Jassie:
Code:
BeagleBoard.org Debian Image 2017-02-26
and Botic kernel:
Code:
Linux beaglebone 4.8.13-botic7-rc3 #1 PREEMPT Sat Dec 10 01:35:51 CET 2016 armv7l GNU/Linux
For some time I have an issue with date/time in my system. After boot/reboot I see old date/time:
Code:
root@beaglebone:~# date
Thu Dec 28 22:14:56 CET 2017
How can I restore the automatic date/time update at system startup/boot?
TIA
Old 11th May 2018, 08:42 PM   #2466
Kernel 4.8 is different a lot, you might want to update the whole system. What invokes your ntpdate now?
Old 12th May 2018, 04:18 AM   #2467
Originally Posted by cu6apum View Post
...., you might want to update the whole system
Thanks.
I'll wait for a new botic kernel
Based on:
Setting the Beaglebone Black (BBB) Time Automatically using NTP | derekmolloy.ie
I installed ntp and set ntpd and ntpdate services. After that it seems like date/time is correct.
Old 21st May 2018, 02:08 PM   #2468
Kanutus is offline Kanutus
Hi! I was wondering if anyone knows if there is a way to update to the latest MPD/MPC with Botic (4.8.13-botic7-rc3), so to enjoy the latest features there? I like to use a minimal interface to play music, so either mpc directly or ympd which is available on Botic's system.
Thanks!
Knut
Old 21st May 2018, 05:44 PM   #2469
fred_com is offline fred_com  Russian Federation
Hi, I may be mistaken, but there is no easy way to get latest MPD on current Botic image.
I had to go the long route - write vanilla Debian image onto SD card, then build the latest MPD from source, and apply the Botic driver.
I can post detailed instruction, if you (or someone else) need one.
Thanks,
Fedor
Old 21st May 2018, 06:45 PM   #2470
Hi Fedor! A detailed instruction would be great! I have not been doing a lot of Linux stuff, so the level of details can probably not be too high!
Cheers!
Knut
Support for Botic Linux driverHide this!Advertise here!
Thread Tools
Open baffle with fullrange driver and bass support Godzilla Full Range 5 22nd July 2011 01:32 PM
Low end support for single driver monitors strider75 Multi-Way 97 30th September 2009 03:02 PM
ASIO support (driver) for Labview Aoxomox Digital Line Level 0 3rd May 2009 05:29 PM
Linux/BruteFIR support coming in LspCAD tcpip Multi-Way 18 18th October 2005 03:08 AM
linux badgers Introductions 3 3rd April 2005 03:27 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
