Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 10th May 2017, 12:51 PM   #2271
francolargo is offline francolargo  United States
Originally Posted by ced View Post
Which leads to an interesting question... I have stopped buying hi rez files as they are stupidly expensive and I cannot for the life of me hear the slightest difference between redbook CD and 192/24, DSD or anything inbetween with hermes,cronus,buff III. This with about 4 A-B test albums (same album different rez). Now I'm pretty sure its not me or my system because we've both been ruthlessly tweaked over 20 years of modding and the difference in quality of the original recordings is night and day. Anyone else same experience or am I missing something?
cheers
Ced
Off topic and esoteric (apologies! ), but interesting because I've had similar experiences. For me, closing the *difference* between sound quality of redbook vs. higher-res sources came mostly from improving the quality of power to all components, but especially the DACs. But for playing through speakers, power quality has not been the only differentiating factor. I believe different driver designs and materials can permit more or less *intra-cone distortion that benefits from higher sampling rates*. Addressing that directly sounded like improving power quality to the various components upstream of the amps. After much tweaking, the downside of having such a high resolution system is that not so many recordings are recorded and mastered well enough to bring out the very best in the music. In my experience, the better the system, the more important is engineering of the recording and the less important is its sample rate.
Old 10th May 2017, 04:32 PM   #2272
ichiban is offline ichiban  United States
It's always something!
ichiban's Avatar
Support for Botic Linux driver
How true. The dB/Loudness mess that too many mastering engineers have been into this past decade and longer is sad. Here is a web site with a list of albums and the recorded dynamic range.
Album list - Dynamic Range Database
-ICHIBAN
BBB w/botic hermes/cronus TP Pro38 w/mercury I/V (powered by Salas UltraBiB 1.3) into a PASS-VFet into SEAS Thors'
Old 10th May 2017, 09:12 PM   #2273
mr_whocares is offline mr_whocares  Germany
Originally Posted by stefan646 View Post
Hello all,
I am also tring to split the right an left data for the DDAC, but using latest Volumio I can't manage to make it work. What else I have to do/modify besides the things listed here A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)
Thank you !
yes, you are right! it seems that this does not work for volumio 2. i have tried that with all versions of the volumio2 and non of them worked. i got the message " can not open the output device" as soon as the botic split alsa is selected as output device. i reported that to michelangelo long time ago but no reply ;-) .... however, the botic split works perfectly with the boticized volumio 1.55 :-)
Old 11th May 2017, 05:05 AM   #2274
stefan646 is offline stefan646
Could you or somebody else give me a link to download volumio 1.55?
Thank you !
Old 11th May 2017, 06:54 AM   #2275
AndrewLv is offline AndrewLv
Stefan646, here you are https://cloud.mail.ru/public/MDbu/6Re84BvSn
Old 11th May 2017, 05:31 PM   #2276
Originally Posted by AndrewLv View Post
Thank you Andrew, but I don't why my BBB don't want to but this image and the official(from volumio website) 1.5 as well. The 2+ version boots with no problem
EDIT: I am burning the SD card using Win32DiskImager - is this the wrong way for 1.5 version?
Old 12th May 2017, 05:02 AM   #2277
Hi Stefan!
It's a right way to use Win32DiskImager for any version of Volumio.
I think your issue with booting should be looked for in uEnv.txt file.
Old 28th May 2017, 04:41 AM   #2278
linuxfan is offline linuxfan  Australia
At May 2017 I see the latest image is 4.8.13-botic7-rc3_1
Q1. after installing the full botic-v4 image to MicroSD card,
then "ntpdate pool.ntp.org"
then "apt-get update"
can I update directly to 4.8.13-botic7-rc3_1 ?
Q2. do I update with "apt-get install" or download the deb first, and install with "dpkg -i"
Thanks.
Old 28th May 2017, 07:46 AM   #2279
OK, on a fresh botic-v4 installation I just used dpkg to install 4.8.13-botic7-rc3_1
as well as the corresponding 4.8.13 firmware.
Now when I boot up the 1st LED on the Hermes board fails to light, indicating that the output of the isolator is NOT enabled, so not external clock, and no output to Cronus.
Old 28th May 2017, 08:21 AM   #2280
twluke is offline twluke  Japan
Did you edit the /boot/uEnv.txt so that the line of dtb=am335x-boneblack-botic.dtb is included in it?
You might want to follow the instruction by miero. It was written for 4.5.0-botic7-rc1 but can be applicable to 4.8.13-botic7-rc3_1.
Support for Botic Linux driverHide this!Advertise here!
Open baffle with fullrange driver and bass support Godzilla Full Range 5 22nd July 2011 01:32 PM
Low end support for single driver monitors strider75 Multi-Way 97 30th September 2009 03:02 PM
ASIO support (driver) for Labview Aoxomox Digital Line Level 0 3rd May 2009 05:29 PM
Linux/BruteFIR support coming in LspCAD tcpip Multi-Way 18 18th October 2005 03:08 AM
linux badgers Introductions 3 3rd April 2005 03:27 PM
Copyright ©1999-2019 diyAudio
